[Ground-station] Now that we've heard some good news... LDPC block work needed - LDPC team alert
Ron Economos
w6rz at comcast.net
Fri Oct 26 23:34:29 PDT 2018
Here's a 2 minute 46 second video showing the LDPC block in action with
some very noisy QPSK. For that run, there were only 9 uncorrected bits
out of 87,350,400.
File length is 116,752,397 bytes.
http://www.w6rz.net/ldpc.mp4
The repository is at:
https://github.com/drmpeg/gr-dvbldpc
On 10/25/18 09:17, Michelle Thompson via Ground-Station wrote:
> Update: Ron W6RZ has a draft GNU Radio block in progress.
> Ahmet also has BCH code. As you all know, DVB-S2/X uses concatenated
> LDPC-BCH forward error correction. We have spent some time talking
> about and learning about LDPC, but BCH is in there too.
> On Wed, Oct 24, 2018 at 1:56 PM Ahmet Inan <xdsopl at gmail.com
> <mailto:xdsopl at gmail.com>> wrote:
> Fixed it on the master branch.
> Ahmet
> On Wed, Oct 24, 2018 at 10:21 PM Michelle Thompson
> <mountain.michelle at gmail.com <mailto:mountain.michelle at gmail.com>>
> wrote:
> > Just keeping everyone in the loop:
> > Ron reports that if we want Ubuntu 16.04 compatibility, then it
> has to work with gcc 5.4. He says that specifically, std::clamp
> isn't available.
> > -Michelle W5NYV
> > On Wed, Oct 24, 2018 at 5:23 AM Ahmet Inan <xdsopl at gmail.com
> >> Yeah, I did the math last night to get soft information from BPSK,
> >> QPSK and 8PSK modulation and it would be nice if someone could look
> >> over it.
> >> I am not entirely sure if I got the SNR stuff right but it
> works very well.
> >> Also, please beware that my 8PSK is Pi/8 rotated.
> >> I put the new PSK stuff into the psk branch in order not to disturb
> >> the others using the master tree:
> >> https://github.com/xdsopl/LDPC/tree/psk
> >> Ahmet
> >> On Wed, Oct 24, 2018 at 1:32 PM Michelle Thompson
> <mailto:mountain.michelle at gmail.com>> wrote:
> >> > Thank you Ahmet.
> >> > I believe your next goal is performance improvements with PSK?
> >> > Is there anything that we can do to help out with this part?
> >> > -mdt
> >> > On Tue, Oct 23, 2018, 23:30 Ahmet Inan <xdsopl at gmail.com
> >> >> Just fixed the few issues regarding g++ compatibility.
> >> >> You can switch between clang++ and g++ in the Makefile.
> >> >> Ahmet
> >> >> On Wed, Oct 24, 2018 at 8:17 AM Michelle Thompson via
> Ground-Station
> >> >> <ground-station at lists.openresearch.institute> wrote:
> >> >> > Ron reports that the Clang dependency is problematic. A
> conversion to gcc will/should be discussed.
> >> >> > On Tue, Oct 23, 2018, 14:25 Michelle Thompson
> wrote:
> >> >> >> We heard some good news yesterday.
> >> >> >> But there is bad news!
> >> >> >> The bad news is that we aren't done yet, and have plenty
> to do!
> >> >> >> I'm working on getting the DVB-S2/X code donation from
> Aerospace Corporation (offered at the GRCon18 Block Party) into
> the code base of GNU Radio. In the meantime, we have a recently
> published open source LDPC repository that we should look at,
> right now.
> >> >> >> This is written by Ahmet Inan, Co-founder & CEO aicodix
> GmbH. They are located in Germany and is on our Slack.
> >> >> >> Recent bugs in this codebase have been sorted out. Can we
> get this into a GNU Radio block and tested ASAP?
> >> >> >> There is at least one other potential code base from a
> local LDPC expert, but it needs some work before release.
> >> >> >> Can we get something ready for review by this weekend?
> >> >> >> -Michelle W5NYV
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20181026/ea7220ba/attachment.html>
