[Ground-station] Now that we've heard some good news... LDPC block work needed - LDPC team alert
Ahmet Inan
xdsopl at gmail.com
Wed Oct 24 13:55:50 PDT 2018
Fixed it on the master branch.
Ahmet
On Wed, Oct 24, 2018 at 10:21 PM Michelle Thompson
> Just keeping everyone in the loop:
> Ron reports that if we want Ubuntu 16.04 compatibility, then it has to work with gcc 5.4. He says that specifically, std::clamp isn't available.
> On Wed, Oct 24, 2018 at 5:23 AM Ahmet Inan <xdsopl at gmail.com> wrote:
>> Yeah, I did the math last night to get soft information from BPSK,
>> QPSK and 8PSK modulation and it would be nice if someone could look
>> over it.
>> I am not entirely sure if I got the SNR stuff right but it works very well.
>> Also, please beware that my 8PSK is Pi/8 rotated.
>> I put the new PSK stuff into the psk branch in order not to disturb
>> the others using the master tree:
>> https://github.com/xdsopl/LDPC/tree/psk
>> Ahmet
>> On Wed, Oct 24, 2018 at 1:32 PM Michelle Thompson
>> > Thank you Ahmet.
>> > I believe your next goal is performance improvements with PSK?
>> > Is there anything that we can do to help out with this part?
>> > -mdt
>> > On Tue, Oct 23, 2018, 23:30 Ahmet Inan <xdsopl at gmail.com> wrote:
>> >> Just fixed the few issues regarding g++ compatibility.
>> >> You can switch between clang++ and g++ in the Makefile.
>> >> Ahmet
>> >> On Wed, Oct 24, 2018 at 8:17 AM Michelle Thompson via Ground-Station
>> >> <ground-station at lists.openresearch.institute> wrote:
>> >> > Ron reports that the Clang dependency is problematic. A conversion to gcc will/should be discussed.
>> >> > On Tue, Oct 23, 2018, 14:25 Michelle Thompson <mountain.michelle at gmail.com> wrote:
>> >> >> We heard some good news yesterday.
>> >> >> But there is bad news!
>> >> >> The bad news is that we aren't done yet, and have plenty to do!
>> >> >> I'm working on getting the DVB-S2/X code donation from Aerospace Corporation (offered at the GRCon18 Block Party) into the code base of GNU Radio. In the meantime, we have a recently published open source LDPC repository that we should look at, right now.
>> >> >> This is written by Ahmet Inan, Co-founder & CEO aicodix GmbH. They are located in Germany and is on our Slack.
>> >> >> Recent bugs in this codebase have been sorted out. Can we get this into a GNU Radio block and tested ASAP?
>> >> >> There is at least one other potential code base from a local LDPC expert, but it needs some work before release.
>> >> >> Can we get something ready for review by this weekend?
>> >> >> -Michelle W5NYV
>> >> > _______________________________________________
>> >> > Ground-Station mailing list
>> >> > Ground-Station at lists.openresearch.institute
>> >> > http://lists.openresearch.institute/mailman/listinfo/ground-station
>> >> Ahmet Inan
>> >> Co-founder and CEO of aicodix GmbH
>> >> https://www.aicodix.de/
>> Ahmet Inan
Ahmet Inan
