[Ground-station] moving away from github
Jan Schiefer
jan at akalaitis.net
Thu Dec 6 15:58:57 PST 2018
Fair enough. I updated documentation on https://github.com/phase4ground/ka9q-sdr <https://github.com/phase4ground/ka9q-sdr> to include a reference to your repos, and created an issue (https://github.com/phase4ground/ka9q-sdr/issues/7) to track progress on mirrorring.
Cheers,
Jan
> On Dec 6, 2018, at 3:53 PM, Phil Karn <karn at ka9q.net> wrote:
> On 12/6/18 15:37, Jan Schiefer wrote:
>> Do you have a guess how often you will update these? I will set up semi-automatic mirroring of some sort, probably just stick incoming changes onto a branch in phase4ground/ka9q-sdr. Polling the file with a cron job is probably the way to go, unless you can recommend something fancier.
> As with any project, it'll depend on how active I happen to be. It's so
> easy to update a website tarball (tar, then rsync) that (unlike github)
> keeping my public copy in sync with my actual work is no problem at all.
> A mirror would still be appreciated, if only as another offsite backup.
> Can't ever have too many. Thanks.
> Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20181206/a4db31b7/attachment.html>
