[Ground-station] 5GHz amplifiers
Tue Apr 24 08:25:08 PDT 2018
The PC Board is the easy part.
Who installs that microscopic little thing?
Virtually has to be done by machine.
Kent WA5VJB
From: Michelle Thompson via Ground-Station <ground-station at lists.openresearch.institute>
Sent: Tuesday, April 24, 2018 10:19 AM
Subject: [Ground-station] 5GHz amplifiers
Julian KF4MOT recommended (#5ghz_rf on Slack) looking at this amplifier:
http://www.skyworksinc.com/Product/4074/SKY66288-11
so I bought 10 of them. I would like to lay out a board for them and get them up and running and useful for our uplink.
Mike Seguin, John Petrich, Chuck Clark, Kent Britain, and several others have extensive experience here and have results for a PCB filter among other things necessary for a successful "get a typical SDR signal heard loud and clear" mission.
What can I do to help get this board built?
I have a circuit printer, but if it's not good enough then we have experience now with two good contract manufacturers on the JoCo/Trans-Ionospherics. I'm sure that Mike and Kent and the others have a wealth of options for making boards as well, and at these frequencies.
Julian explained that heat dissipation is the first thing to take care of.
-Michelle W5NYV_______________________________________________
Ground-Station mailing list
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180424/c56d07d9/attachment.html>
