Douglas Quagliana
dquagliana at gmail.com
Tue Apr 24 08:16:12 PDT 2018
After spinning up an Ubuntu 16.04LTS machine, and installing the
dependencies in the dependencies file, it compiles (with a few warnings,
but it compiles).
(warning on ignoring the return value from asprintf) then it ends saying
that there is no rule to make 'bandplan.txt', so the makefile needs a small
tweak.
Add a dependency on gcc - the one in 1404LTS doesn't seem to work but gcc
5.4.0 in 1604LTS seems to be okay.
Douglas
On Tue, Apr 24, 2018 at 8:53 AM, Michelle Thompson <
> Thank you Jan.
> I would like to keep the project repository current with this code.
> Phil is a novice at github, and could use the help in learning how to use
> it.
> I’ll add you to the team I set up for him as the maintainer on our Github.
> Maybe after he sees the process it will be easier for him to collaborate.
> *mdt
> On Tue, Apr 24, 2018 at 02:16 Jan Schiefer via Ground-Station
>> > In the file named "dependencies". Look in ka9q/ka9q-radio, not
>> > phase4ground/ka9q-sdr. I created and began to revise the first before I
>> > realized I'd created a private repository. If somebody can figure out
>> > how to just rename the whole thing, I gladly will.
>> > You know, "mv ka9q/ka9q-radio phase4ground/ka9q-sdr"
>> > I also put stuff in phase4ground/ka9q-sdr but I have NOT been updating
>> > it. I should probably delete it so it won't confuse people.
>> I merged the changes, but I don't have write permissions for
>> phase4ground/ka9q-sdr. Michelle, if you want to give me write
>> permissions, I'll push it. If you'd rather I sent you a pull request,
>> that's perfectly fine, too.
>> The intended end result is that the contents of ka9q/ka9q-radio and
>> phase4ground/ka9q-sdr will be the same, with the one exception of the
>> LICENSE file, which I assume we would want in there.
>> Cheers,
>> Jan, ac7td
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180424/820e906c/attachment.html>
