Robert McGwier
rwmcgwier at gmail.com
Mon Apr 23 09:49:00 PDT 2018
Agree with Phil
On Mon, Apr 23, 2018, 12:40 PM Phil Karn via Ground-Station
> On 4/23/18 08:45, Michelle Thompson wrote:
> > There are some ambitious ideas for matching linear polarization
> > (automated closed loop) for something that is tumbling around like a
> > balloon payload probably would. Don't rule it out just because it sounds
> > hard. We live in a golden age.
> Balloon payloads do swing in pitch and yaw, but not that much.
> cos(x) ~ 1 for small x.
> The real problem is that the yaw is completely uncontrolled and can
> change rapidly. Controlling this yaw is possible but difficult (I've
> been thinking about it for a while). But simple knowledge of yaw might
> suffice and would be much easier -- use an IMU with AHRS software.
> This will require an omni antenna (with low gain), a steerable gain
> antenna, or a set of directional antennas fixed to the payload and
> selected electrically.
> In the second category, the Qualcomm Omnitracs taco-shell antenna might
> be a very workable design. The requirements are very similar:
> azimuth-only control would be adequate, especially with a fan beam wide
> in elevation. Vertical polarization would be fine. If a surplus
> Omnitracs antenna could be modified, that would be ideal. Otherwise, the
> rotating reflector could probably be 3D printed.
> If an Omnitracs antenna could be modified for the payload, one could
> also be used on the ground. The only drawback here is a wide fan beam in
> elevation.
> Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180423/015ff60a/attachment.html>
