Zach Leffke
zleffke at vt.edu
Sun Apr 22 20:57:29 PDT 2018
To Bruce's point, the ground based reference would eliminate the need
for a freq reference onboard the payload. Would definitely save on SWaP
that way.
Would just have to make sure it has enough juice to be heard on the
payload. Geometry is also a major factor......particularly with respect
to antenna patterns. Depending on winds aloft, antenna patterns,
antenna pointing on the balloon/ground, and expected travel of the
payload, it might be worth having a few beacons along the expected path
of the balloon to make sure at least one is always 'in view' of the
payload that's nice and strong. Also, if planning to 'scan' the rx freq
(maybe top/bottom halves of the 5 GHz uplink band?) then having multiple
beacons on different freqs on the ground could be useful.
Co-locating the beacons on chase vehicles (assumption is that folks are
chasing, probably via APRS) might simplify things a bit. CW with
callsigns to identify/differentiate between the beacons......and since
the vehicles are moving, probably want ground recordings of the GPS
coordinates of the beacons.
Many 'dimensions' to the tradeoff.....but overall, a bit more complexity
on the ground is probably worth the savings on SWaP on the payload. Or
if SWaP and the parts are available, might as well use it to reduce
complexity on the ground.
Also, FAA requirements need to be checked by someone.....its been awhile
since I've done one of these flights......I think I remember something
about a 6 pound limit (there is a density requirement too...can't fly a
6 pound cannon ball). Also no cordage with greater than 50lb test. I
believe there is a secondary cut down requirement as well (in case the
balloon doesn't pop and you hit equilibrium).
Fun Stuff!
-Zach
Aerospace Systems Lab
On 4/22/2018 11:17 PM, Michelle Thompson wrote:
> I'll be working at Kerry Banke's tomorrow on 10GHz and will run it by
> him as well.
> We have almost all the elements on hand, including an odroid with GNU
> Radio.
> I can print an antenna if needed.
> -mdt
> On Sun, Apr 22, 2018, 20:12 Bruce Perens via Ground-Station
> I have been using Odroid rather than Raspberry Pi cor just that
> reason. Pi has poor IO bandwidth.
> If frequency precision is why you'd like an oxco, would a ground
> beacon that is recorded provide enough?
> On Sun, Apr 22, 2018, 19:53 Zach Leffke via Ground-Station
> I like this idea......it has elements of a couple projects
> that I've worked on in the last year or so.
> I just did similar math from a slightly different angle......
> 10 Msamp/sec complex capture (so 10 MHz of spectrum, using GNU
> Radio Complex datatype) at 64 bits per sample yields roughly
> 1.86 hours of record time on a 500 GB SSD......about perfect
> for this type of balloon flight.......go up, burst, come back
> down. The recording could be triggered at a specific time or
> altitude to optimize the collect.
> I'd recommend the XU4 over the RPi as it has two USB 3.0
> ports, one for a B200 mini, and one for an external USB3.0
> SSD. also its got a beefier processor and more RAM, better to
> keep up with the write speeds.
> A B200 mini is tiny and relatively cheap, though it would
> probably need a 10 MHz reference of some sort (could be a
> GPSDO, but would need to make sure the GPS works at
> altitude......standalone OCXO might be a better solution). It
> also has a similar RF front end to the Astrod SDR (an ADXXXX
> whatever whatever, I can't remember off the top of my head,
> but same family at least).
> For the 2017 Eclipse experiment (recording satellite
> downlinks, looking for Scintillation effects due to the
> eclipse) I used a very similar setup to this and used a simple
> script to control the flowgraph recording....one minute on,
> one minute off. I ended up with hours of 1 minute IQ
> recordings started at every odd minute. Something like that
> could be used here, with the possibility of tweaking
> parameters between each recording (like stepping the USRP gain
> in 10dB increments each time, or possibly changing center
> freq). Log files or the filename itself could be used to keep
> track of which IQ capture had what settings.
> Marc Franco has designed and I believe built some 5 GHz
> pre-amp prototypes for the uplink band...might be good to give
> them a test.
> Ground based 'reference beacons' might be useful/fun. Maybe
> sending out CW at known center freqs at known power levels to
> give a reference to hunt for in the collects.
> Any ideas on antenna types? patch array? horn? conical
> spiral? circular or linear (I vote circular on the balloon,
> pointed at Nadir)?
> This sounds like a perfect summer project for some of our
> undergrads!
> -Zach, KJ4QLP
> Research Associate
> On 4/22/2018 1:20 AM, Phil Karn via Ground-Station wrote:
>> On 4/20/18 10:07, Douglas Quagliana via Ground-Station wrote:
>>> I would like to suggest sending up a software defined radio that can
>>> recording on (and around) the proposed uplink frequencies. It should
>>> sample at the highest sampling rate possible to capture the widest
>>> bandwidth possible into the recording.
>> Let's see... what sample rate would fill a 256GB thumb drive during a
>> typical 2 hour balloon flight?
>> 256e9 bytes / 4 bytes/sample = 64 gigasamples assuming 16 bit complex
>> samples. Over 2 hours that would be a sample rate of 64e9/7200 = 8.89
>> megasamples/sec. I.e., we could collect 8+ megahertz of spectrum,
>> depending on the anti-alias filters. You'd have to make sure that the
>> drive can write continuously at that rate. A SSD might be necessary.
>> Plenty for the 2m/70cm satellite subbands or for the entire 2m band, but
>> not the entire 70cm band. It would be fun going through these recordings
>> with my 'radio' program.
>> Most latex weather balloons maintain a remarkably constant ascent rate
>> of 1,000 fpm (5 m/s) and burst at 100,000-120,000' (30.5-36.5 km). Ergo
>> the ascent time would be 100-120 minutes or from 1 hr 40 minutes to 2
>> hr. The ascent is somewhat turbulent until the turbopause, then things
>> usually smooth out in the stratosphere. At altitude it's positively
>> serene until the balloon bursts. Then all hell breaks loose.
>> This assumes hydrogen. Pretty much everybody uses it now since helium is
>> getting scarce and bloody expensive. Treat it with respect and you'll
>> have no problems.
>> The descent by parachute usually takes about 30 minutes. Descent is VERY
>> quick at first because of the thinner air (1% of surface density at 32.6
>> km) but then slows as it descends into exponentially denser air.
>> Descents are pretty violent due to turbulence (especially if the remains
>> of the balloon are still attached) so it might not be worth collecting
>> data on the way down since you're seeing much the same area anyway. It's
>> easy to get sick watching HDTV of a descent on a large screen...
>> Phil
>> <mailto:Ground-Station at lists.openresearch.institute>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180422/21c961ab/attachment.html>
