Douglas Quagliana
dquagliana at gmail.com
Sun Apr 22 06:10:17 PDT 2018
The original text says that this ran from a command line on Linux. I did a
git clone, ran make but got numerous errors compiling (bsd/strings.h) and
errors linking (-lbsd in particular)
I'd love to try it and make a GUI (if I can).
Which Linux distribution did you use?
Which version of gcc?
Douglas
On Saturday, April 21, 2018, Michelle Thompson via Ground-Station
> This software is in the repository here https://github.com/
> phase4ground/ka9q-sdr
> On Sat, Apr 21, 2018 at 9:48 PM, Phil Karn via Ground-Station <
>> On 4/21/18 14:36, Douglas Quagliana via Ground-Station wrote:
>> > Hi Michelle,
>> > Here's my first pass. Suggested changes:
>> > change "aquire" to "acquire"
>> > change "unecessarily" to "unnecessarily"
>> > change "Curently" to "Currently"
>> > change ""imabalance" to "imbalance"
>> > change "ony" to "only"
>> > change "demdulator" to "demodulator"
>> > change ""operating moded" to "operating mode" ?
>> > change "recordingq" to "recording"
>> Yeah, I didn't run a spell checker before I shipped it off.
>> > For the sentence containing "...this noise is only
>> > noticeable in without antenna noise covering it up"
>> > remove the "in" or rewrite.
>> > I would suggest a slightly different frequency for the example
>> > "147m435" (147.435 MHz) as "435" is frequently used in the
>> > context of 435 MHz (at least for satellite work) and this might
>> > cause some confusion.
>> I picked 147.435 as an in-joke for hams in southern California. It's the
>> output of the infamous "animal house" repeater in Los Angeles. But point
>> taken.
>> > In written text, the FUNcube dongle is usually written as "FUNcube"
>> > with the first three letters capitalized (Source:
>> > http://www.funcubedongle.com/)
>> I was wondering about this. "Funcube dongle pro+" is a bit of a mouthful
>> but "Funcube" by itself refers to the satellite.
>> > Is there a link to download the software?
>> There will be...
>> Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180422/b184c84f/attachment.html>
