Douglas Quagliana
dquagliana at gmail.com
Sat Apr 21 14:36:23 PDT 2018
Hi Michelle,
Here's my first pass. Suggested changes:
change "aquire" to "acquire"
change "unecessarily" to "unnecessarily"
change "Curently" to "Currently"
change ""imabalance" to "imbalance"
change "ony" to "only"
change "demdulator" to "demodulator"
change ""operating moded" to "operating mode" ?
change "recordingq" to "recording"
For the sentence containing "...this noise is only
noticeable in without antenna noise covering it up"
remove the "in" or rewrite.
I would suggest a slightly different frequency for the example
"147m435" (147.435 MHz) as "435" is frequently used in the
context of 435 MHz (at least for satellite work) and this might
cause some confusion.
In written text, the FUNcube dongle is usually written as "FUNcube"
with the first three letters capitalized (Source:
http://www.funcubedongle.com/)
Is there a link to download the software?
Still checking,
Douglas KA2UPW/5
On Sat, Apr 21, 2018 at 2:01 PM, Michelle Thompson via Ground-Station <
> Call for Comment and Critique. Contents are below. File is also attached!
> See most recent weekly report for an introduction to this package.
> -mdt
> ka9q-radio
> Overview
> This is a collection of software defined radio (SDR) modules connected
> by the Internet Real Time Protocol (RTP) and IP multicasting. It is
> intended to facilitate experimentation and education, and to be easy
> to interface to data decoders and digital communication programs. It
> can also smoothly track satellite Doppler shift in an open-loop mode
> when fed velocity and acceleration information from an external
> program.
> The ka9q-radio modules currently execute from the command line on
> either Linux or OSX. As yet there is no fancy graphical user
> interface. (This may come later, especially if someone volunteers to
> create one).
> Multicasting and the Real Time Protocol
> The ka9q-radio modules are designed for maximum versatility. Unlike
> shell pipelines or TCP/IP connections, ka9q-radio modules can be
> individually started and stopped at any time, and one can feed any
> number of others without prearrangement. They can run on the same
> computer or on different computers on a multicast-capable network
> (e.g., an Ethernet LAN).
> RTP is widely used for point-to-point voice over IP (VoIP), though it
> was designed for multicasting with any codec or data
> format. ka9q-radio uses four RTP payload types: raw I/Q data with a
> custom receiver status header; mono or stereo 16-bit uncompressed PCM
> audio sampled at 48 kHz; and the new Opus codec.
> It should be easy to add PCM/RTP input to any ham SDR program that
> uses a computer sound card to aquire receiver audio (e.g. WSJT-X,
> fldigi and many others). This would bypass the computer's sound system
> and providing a much cleaner and more reliable interface. No analog
> audio cables, "rigblaster" adapter boxes, audio ground loops,
> equalization problems, or tricky level adjustments! With multicasting,
> any number of programs can process the same receiver output.
> Parts of the ka9q-radio package should also be well suited to
> "turnkey" networked receiver applications such as receive-only
> APRS-to-Internet gateways and Broadcastify feeds.
> Opus Compression and Audio Monitoring
> Although PCM is best for digital decoders, it requires 800 kb/s for
> mono and 1.6 Mb/s for stereo. Much lower data rates suffice for human
> listening over WiFi or a remote Internet connection. I use the new
> Opus codec standardized by the Internet Engineering Task Force
> (IETF). A high quality, open-source Opus implementation is available,
> and it can be freely used without patent restrictions (unlike, e.g.,
> ABME). Opus automatically switches algorithms as needed to do the
> best it can with whatever data rate is available, from very high
> fidelity stereo audio at up to (an unecessarily high) 510 kb/s down to
> monaural voice at only 6 kb/s. (VK5DGR's CODEC2 can handle even lower
> data rates, which is on my to-do list.) I typically use 32 kb/s,
> which is actually much higher than needed for communications-quality
> audio.
> Popular media players like VLC support PCM and Opus so you can listen
> to ka9q-radio audio on many smartphones and tablets. Curently the
> player must receive multicasts, which usually means they must be on
> the same LAN as the computer(s) generating the audio streams. Remote
> unicast Internet connectivity is on the to-do list.
> The ka9q-radio package also includes 'monitor', a RTP audio player
> that can receive and mix several multicast audio streams to the local
> sound output. It has a novel 'pan' feature that uses gain and delay
> adjustments (<1 ms) to place each source at a user-chosen point in a
> stereo image. This makes it easier to distinguish multiple sources,
> e.g., in a round table. The 'monitor' program currently supports only
> Opus and PCM, though CODEC2 is on the list.
> The KA9Q 'radio' program
> The heart of the ka9q-radio package is the program 'radio', an
> interactive general coverage receiver. It reads raw I/Q data multicast
> by a SDR front end, sending tuning and gain adjustments as
> needed. radio's output is a mono or stereo PCM audio multicast
> stream.
> If audio compression is needed, a separate 'opus' module transcodes
> PCM to Opus. I.e., it receives PCM, compresses it with Opus and
> multicasts it to a different IP address. This lets listeners and
> players select compressed or uncompressed audio by merely joining the
> corresponding multicast group.
> A simple but entirely usable textual interactive user interface is
> provided. If desired, it can be disabled entirely with all parameters
> given instead on the command line (e.g., in shell scripts).
> Architecture
> The 'radio' program accepts a generic I/Q (complex) sample stream
> multicast by a computer with a direct conversion ("zero IF") SDR front
> end. At present, only the AMSAT UK Funcube Pro+ dongle is supported
> with the 'funcube' module. The (mostly higher) sample rates produced
> by other receivers such as the SDRPlay and RTL-SDR are supported but
> only the Funcube's 192 kHz sampling rate has actually been tested.
> An I/Q stream at 192 kHz with 16 bit samples is a constant 6.5 Mb/s
> network load; this is no problem for modern Ethernet but it should be
> kept away from inexpensive WiFi base stations and public Internets.
> (More on problems with multicast and WiFi in the end notes).
> Hardware Artifact Removal
> Although a SDR front end is typically direct conversion, the complete
> ka9q receiver is actually a dual-conversion superheterodyne: the first
> LO and mixer are in analog hardware and the second LO and mixer are in
> software. The first mixer is the quadrature (I/Q) type that produces a
> complex first IF centered on zero Hz and extending from -Fs/2 to
> +Fs/2, where Fs is the A/D sample rate. For the Funcube dongle, Fs =
> 192 kHz so the IF extends 96 kHz above and below the first LO
> frequency. (For a complex signal, the Nyquist rate is equal to the
> bandwidth; for a more familiar real signal, the Nyquist rate is twice
> the signal bandwidth.)
> This is often called a "zero IF" architecture but this is a slight
> misnomer. The actual first IF can be anywhere between -Fs/2 and +Fs/2
> provided it contains the entire signal bandwidth, though the 10 kHz
> near each edge from a Funcube dongle is best avoided because of
> imperfect anti-alias filtering before the A/D converters.
> There is also a "DC spike" at 0 Hz from crosstalk from the first LO to
> the receiver input. The first processing step in 'radio' completely
> removes this spike, but reciprocal mixing produces some low frequency
> phase noise that cannot be removed. With the Funcube dongle this noise
> is only noticeable in without antenna noise covering it up, but it is
> still best avoided. E.g., the range from +48 kHz to +51 kHz (or -51
> kHz to -48 kHz) might be selected for SSB with a 3 kHz bandwidth.
> This is still an extremely low IF by usual standards as adequate image
> rejection cannot be provided by ordinary filtering. The use of complex
> I/Q signals allows the frequency image to be cancelled with digital
> signal processing. This requires the 'radio' program to compensate for
> any slight gain and phase imbalances between the I and Q channels, and
> this is its second processing step. Typical values for the Funcube
> dongle might be 0.07 dB of gain imabalance and 0.4 degrees of phase
> error.
> Frequency conversion
> The third step is to convert the first IF signal to baseband, i.e., 0
> Hz. This is performed by the second (software) LO and mixer in complex
> arithmetic, which suppresses the unwanted image in the other half of
> the IF. The LO and mixer each require only one complex multiply per
> sample. Sine and cosine calls are needed ony when the LO is retuned.
> Another LO and mixer are optionally used for open-loop correction of
> satellite Doppler shift. The 'radio' program reads velocity and
> acceleration from an external program, calculates and applies the
> appropriate frequency offset and rate.
> Filtering and Demodulation
> The baseband signal is filtered with fast correlation. With complex
> signals, the passband can be asymmetric, e.g., +100 to +3000 Hz
> selects upper sideband (USB) and -100 to -3000 Hz selects LSB. A
> post-detection frequency shift is provided for CW; this is equivalent
> to retuning the radio while simultaneously sliding the filter to keep
> the signal at the same point in the passband. Modes other than SSB
> typically use filters centered on 0 Hz but this is not required; the
> edges can be individually varied, e.g. to suppress adjacent channel
> interference.
> The filtered baseband signal is then fed to one of three demodulators:
> 'AM', 'FM' and 'linear.'
> The AM detector implements ordinary noncoherent envelope detection of
> AM signals.
> The FM demodulator handles narrowband frequency or phase modulation.
> Two submodes are provided: 'FM', with a high pass cut on the received
> audio below 300 Hz to remove PL/CTCSS tones and a standard -6
> dB/octave audio de-emphasis above 300 Hz. The 'FMF' mode is straight
> FM without post-detection filtering. Both modes use an FFT to measure
> PL/CTCSS tone frequencies to 0.1 Hz accuracy. SNR, frequency offset
> and peak deviation are also measured and displayed.
> The 'linear' detector is used for all other modes, including SSB/CW,
> ISB (independent sideband) and raw I/Q. In linear mode the filter
> directly feeds the output: both the I and Q channels for stereo modes
> and just the I channel for mono. Stereo is implied by I/Q and ISB and
> is optional for CW/SSB, where it provides an interesting effect
> because of the 90 degree phase shift (Hilbert transform) between the
> channels. This may be useful to minimize fatigue during long
> contests.
> The I/Q and ISB modes are the same except that in ISB the filter
> processes the positive and negative frequency components to force the
> lower sideband onto the I (left) channel and the upper sideband onto Q
> (right).
> A PLL and mixer can track a carrier for coherent (synchronous) AM
> detection, which is usually less noisy than regular AM envelope
> detection. In "calibrate" mode the PLL can adjust a TCXO offset
> estimate to bring the carrier to exactly 0 Hz. This is useful for
> automatic calibration of the SDR TCXO against WWV/H, CHU, an ATSC
> (North American digital TV) pilot carrier, or an external frequency
> reference.
> A squarer can be inserted in the PLL to track the suppressed carrier
> in DSB-AM and BPSK.
> User Interface
> The 'radio' program has a textual user interface that uses the
> "ncurses" library; it may look primitive by 2018 standards, but it is
> lightweight, simple and very efficient over slow Internet paths. The
> 'h' key toggles a list of the supported commands. The textual user
> interface can also be completely disabled and all receiver parameters
> given on the command line, e.g, for invocation from a shell script.
> Startup files are stored in ~/.radiostate (i.e., the directory
> ".radiostate") in the user's home directory). Invoking 'radio' with
> the name of a startup file loads its settings. The state of the radio
> can be saved to a state file with the 'w' key. On normal termination
> the radio state is also stored as "default". It will be automatically
> loaded on the next invocation if no explicit name is given.
> The various operating modes are specified in
> /usr/local/share/ka9q-radio/modes.txt. Each entry specifies a
> demodulator along with filter parameters, the post-detection frequency
> shift, AGC responses and option flags. For example, "USB" selects the
> "linear" demdulator, a filter passband of +100 to +3000 Hz, a zero
> post-detection frequency offset, an AGC attack rate of -50 dB/sec, an
> AGC recovery rate of +6 dB/sec, an AGC hang time of 1.1 seconds and
> mono output.
> The text mode interface provides the following status windows:
> The "Tuning" window shows the radio, LO and IF frequencies. If Doppler
> correction is active, it is also shown here. The user can change
> frequency with the arrow keys, a Griffin PowerMate USB knob, a mouse
> wheel, or with text entered through a popup menu.
> The "Signal" window shows signal, noise and SNR estimates at various
> points in the signal path. Levels are in dBFS, i.e., decibels below
> full scale (A/D saturation) as there is no way to know the gain ahead
> of the A/D converters without careful calibration, which is invariably
> frequency dependent.
> The "Info" window shows, if available, the name of the channel or
> frequency band and, if it's a ham band, the allowed emissions and
> required license class. This information comes from
> /usr/local/share/ka9q-radio/bandplan.txt.
> The "Filtering" window gives the pre-detection filter and
> post-detection frequency shift settings. The filter edges, frequency
> shift and Kaiser window beta parameter can be adjusted in the same way
> as the tuning. Smaller betas give sharper filters but poorer
> stop-band attenuation; larger betas give wider transition bands
> but better rejection outside the passband. [See the later discussion
> about sample rates and decimation.]
> The "Demodulator" window shows mode-specific information. The AM and
> linear modes include a simple fast-attack, slow decay AGC for SSB
> (more work can be done here).
> The "Options" window selects the various options for the "Linear"
> demodulator.
> The "SDR Hardware" window shows the A/D sample rate, TCXO offset,
> nominal tuner frequency, analog gain settings and gain and phase
> imbalance estimates.
> The "Modes" window allows the operating moded to be conveniently selected
> with a mouse click.
> The "I/O" window gives information on the I/Q input and PCM audio
> output network streams: IP addresses or host names; port numbers;
> packet, sample and error counts; and a SDR timestamp useful when
> playing back recorded I/Q data. It also estimates the true I/Q sample
> rate against the local computer time-of-day clock.
> A "Debug" area at the very bottom of the screen shows version information
> and various test and debugging messages.
> Textual user input entered through popup menus; for example a tuning
> frequency can be directly entered as "147m435" (147.435 MHz), 760k
> (760 kHz) or 1g296296 (1296.296 MHz). If no units letter is used, a
> 'best guess' is made to produce a valid frequency; e.g. 14313 will
> give 14.313 MHz, not 14.313 kHz (which is below the Funcube's range).
> Other ka9q-radio Modules
> Other modules provide either miscellaneous functions or begin more
> complex planned features. None of them have especially complex user
> interfaces; most take only a few command line arguments and can run as
> background daemons.
> 'Funcube'
> The 'funcube' module takes I/Q data from a locally connected Funcube
> Pro+, multicasts it over the local LAN and accepts unicast commands to
> tune the radio and set analog gain levels. It will also automatically
> change gain levels to avoid A/D saturation. Similar modules will be
> written for other SDR front ends such as the SDRPlay and RTL-SDR that
> will either talk directly to the hardware or through "shimware" such
> as SoapySDR.
> 'IQrecord' and 'IQplay"
> The 'iqrecord' and 'iqplay' modules perform the functions suggested by
> their names. 'iqrecord' accepts multicast I/Q and PCM audio streams
> and writes them to disk. Gaps in the multicast stream due to lost
> packets or silence suppression are seeked over in the recordingq to
> maintain the
> correct sample count and playback timing.
> I/Q streams are written into files named as 'iqrecord-xxxxxx-n' where
> xxxxxx is the RTP SSRC (Stream Source Identifier) and 'n' is a number
> incremented to avoid overwriting existing recordings. PCM streams are
> written as 'pcmrecord-xxxxxx-n'. Both files are written as raw,
> headerless 16-bit PCM with all meta information in extended file
> attributes.
> Most but not all modern file systems support extended attributes; a
> notable exception is Microsoft's VFAT32 often used as a
> least-common-denominator for file exchange between different operating
> systems. Warning! Many file copy and archiving utilities do not
> preserve extended attributes, at least not by default.
> I/Q and PCM recordings have many uses. An I/Q recording preserves
> everything fed to the 'radio' input regardless of modulation type or
> bandwidth (provided it fits within the receiver passband). This is
> useful for testing and for demonstrating the 'radio' program when an
> antenna is not available.
> I/Q recordings are especially useful as backups during events
> difficult or impossible to reproduce, such as a satellite pass or
> balloon flight. When made at or close to the SDR hardware they depend
> only on the antenna, SDR hardware and I/Q multicast program
> (e.g. 'funcube'). This can guard against bugs (or the outright
> failure) of more complex elements in the downstream signal path, e.g.,
> a digital data demodulator. After the demodulator is fixed, the
> recording can be played back to recover the data.
> 'iqrecord' is an excellent example of multicasting's versatility; it
> can just sit quietly in the corner recording the same I/Q data stream
> being processed by a real-time software receiver or telemetry decoder
> without impairing its function in any way.
> The 'iqplay' module plays back I/Q recordings (only -- no PCM support
> at present) using the metadata contained in the external file
> attributes. It can also read a raw stream from standard input to
> simulate SDR front end hardware.
> 'Opus'
> The 'opus' module was described earlier as an optional "transcoder"
> that accepts uncompressed PCM (either mono or stereo) and produces a
> lower bit rate compressed version with the Opus codec. Options include
> a range of blocksizes from 2.5 milliseconds to 120 ms. The larger
> blocks are useful only to reduce packet rate and header overhead; they
> provide no additional compression and are supported only by more
> recent versions of the Opus library. The default is 20 ms, which is
> long enough to give good compression but short enough to be
> essentially unnoticeable.
> The compressed output data rate is specified by a command line
> parameter; it defaults to 32 kb/s which produces surprisingly good
> audio even on stereo music.
> The Opus codec also supports a VOX-like "discontinuous" mode well
> suited to half-duplex push-to-talk amateur operation. When silence is
> detected, it automatically drops to sending "comfort noise" at only 3
> packets per second.
> "Packet"
> This module is my first digital demodulator module for the ka9q-radio
> package. It accepts PCM audio from the 'radio' program and demodulates
> and decodes standard 1200 bps AX.25 frames using the ancient Bell 202A
> AFSK modem. The decoded AX.25 frames are multicast in UDP packets that
> do not currently have RTP headers; this will probably change. The
> decoded frames can also optionally be displayed on the
> console. Otherwise the module can run as an unattended daemon.
> "APRS"
> This unfinished module accepts decoded AX.25 frames from the "packet'
> module, extracts APRS position data from a selected station, computes
> the azimuth, elevation and range to that station from a specified
> point, and commands antenna rotors to point at the transmitting
> station. This was written to automatically track high altitude
> balloons.
> Footnotes and Sidebars
> Sample Rates and Decimation
> The I/Q input sample rate must be an integer multiple of the 48 kHz
> audio output rate. Decimation is performed as a byproduct of the fast
> correlator used for pre-detection filtering. Since the input FFT in a
> fast correlator executes at the input sample rate, CPU loading will
> increase. Faster and simpler decimators are in the works.
> By default the filter decimates the Funcube 192 kHz A/D input sample
> rate by a factor of 4 to a 48 kHz audio output. Other SDR front ends
> with higher sample rates will require correspondingly higher
> decimation ratios. Although 48 kHz may seem excessive for
> communications-grade audio, I don't recommend reducing it. 48 kHz is
> supported by nearly every audio D/A, and it still uses only 0.154% of
> a gigabit Ethernet link.
> More importantly, the Opus codec strongly prefers 48 kHz stereo even
> for narrowband mono voice, and there seems to be no advantage to mono
> or a lower sample rate (i.e., the compressed data rate is not reduced
> nor is audio quality improved at a given rate.) So if the audio bit
> rate is a concern, just use Opus; don't reduce the PCM sample rate.
> Digital demodulators are best run on computers with fast local network
> connections to the radio program so they can be given uncompressed
> PCM. (Audio compression works by eliminating signal components
> inaudible to the human ear, but which may be very important for a
> digital demodulator.)
> Filter Tradeoffs
> Simultaneously improving both filter rolloff and stop-band attenuation
> requires a longer FIR impulse response, which implies greater latency
> and somewhat increased CPU loading. Currently, the filter blocksize
> and FIR length can only be specified on the command line or in the
> startup file, i.e., they cannot be changed without restarting the
> program. (Note: the length of the FFT executed by the filter is equal
> to the sum of the blocksize and FIR length minus one. The default
> blocksize of 3840 corresponds to 960 samples after 4:1 decimation to
> 48 kHz; this is the number of samples in a 20 ms Opus frame. 3840 +
> 4353 - 1 = 8192, i.e., the FFT has 8k points. While the FFTW package
> can handle any number of points, a power of 2 is more efficient. I've
> found the default parameters to be suitable for most purposes.)
> Correcting Fractional-N Frequency Synthesizer Artifacts
> Because the first LO in the Funcube dongle is an analog hardware with
> the usual synthesizer tuning artifacts, it is retuned only when
> necessary to contain the desired signal in the first IF, i.e., between
> -Fs/2 and +Fs/2. Otherwise tuning is with the second (software) LO
> because it can be smoothly and instantly tuned without any
> glitches. This is especially important with open-loop Doppler
> correction.
> Like most modern radios, the Funcube uses fractional-N frequency
> synthesis with inherent restrictions on the actual set of frequencies
> that can be produced. Although its programming interface advertises 1
> Hz steps, the actual tuning step size varies with frequency; in the HF
> and VHF range it is 1000/2048 = 0.48828 Hz so it cannot produce exact
> 1 Hz frequency steps.
> The 'radio' program works around this in two independent ways. First,
> the hardware synthesizer programming formulas and constants from the
> Funcube firmware are used to determine the actual frequency for any
> requested frequency so the discrepancy can be corrected by the second
> LO. Second, only frequencies that the synthesizer can exactly produce
> are selected; the step size varies with frequency so the worst
> (largest) value of 125 Hz is always used, with the difference again
> absorbed by the second LO. Although these two fixes are specific to the
> Funcube dongle, other SDRs undoubtedly have the same problem subject
> to the same workarounds -- if I can get the necessary details.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180421/a900e116/attachment.html>
