Sat Apr 21 12:01:12 PDT 2018
Call for Comment and Critique. Contents are below. File is also attached!
See most recent weekly report for an introduction to this package.
-mdt
ka9q-radio
Overview
This is a collection of software defined radio (SDR) modules connected
by the Internet Real Time Protocol (RTP) and IP multicasting. It is
intended to facilitate experimentation and education, and to be easy
to interface to data decoders and digital communication programs. It
can also smoothly track satellite Doppler shift in an open-loop mode
when fed velocity and acceleration information from an external
program.
The ka9q-radio modules currently execute from the command line on
either Linux or OSX. As yet there is no fancy graphical user
interface. (This may come later, especially if someone volunteers to
create one).
Multicasting and the Real Time Protocol
The ka9q-radio modules are designed for maximum versatility. Unlike
shell pipelines or TCP/IP connections, ka9q-radio modules can be
individually started and stopped at any time, and one can feed any
number of others without prearrangement. They can run on the same
computer or on different computers on a multicast-capable network
(e.g., an Ethernet LAN).
RTP is widely used for point-to-point voice over IP (VoIP), though it
was designed for multicasting with any codec or data
format. ka9q-radio uses four RTP payload types: raw I/Q data with a
custom receiver status header; mono or stereo 16-bit uncompressed PCM
audio sampled at 48 kHz; and the new Opus codec.
It should be easy to add PCM/RTP input to any ham SDR program that
uses a computer sound card to aquire receiver audio (e.g. WSJT-X,
fldigi and many others). This would bypass the computer's sound system
and providing a much cleaner and more reliable interface. No analog
audio cables, "rigblaster" adapter boxes, audio ground loops,
equalization problems, or tricky level adjustments! With multicasting,
any number of programs can process the same receiver output.
Parts of the ka9q-radio package should also be well suited to
"turnkey" networked receiver applications such as receive-only
APRS-to-Internet gateways and Broadcastify feeds.
Opus Compression and Audio Monitoring
Although PCM is best for digital decoders, it requires 800 kb/s for
mono and 1.6 Mb/s for stereo. Much lower data rates suffice for human
listening over WiFi or a remote Internet connection. I use the new
Opus codec standardized by the Internet Engineering Task Force
(IETF). A high quality, open-source Opus implementation is available,
and it can be freely used without patent restrictions (unlike, e.g.,
ABME). Opus automatically switches algorithms as needed to do the
best it can with whatever data rate is available, from very high
fidelity stereo audio at up to (an unecessarily high) 510 kb/s down to
monaural voice at only 6 kb/s. (VK5DGR's CODEC2 can handle even lower
data rates, which is on my to-do list.) I typically use 32 kb/s,
which is actually much higher than needed for communications-quality
audio.
Popular media players like VLC support PCM and Opus so you can listen
to ka9q-radio audio on many smartphones and tablets. Curently the
player must receive multicasts, which usually means they must be on
the same LAN as the computer(s) generating the audio streams. Remote
unicast Internet connectivity is on the to-do list.
The ka9q-radio package also includes 'monitor', a RTP audio player
that can receive and mix several multicast audio streams to the local
sound output. It has a novel 'pan' feature that uses gain and delay
adjustments (<1 ms) to place each source at a user-chosen point in a
stereo image. This makes it easier to distinguish multiple sources,
e.g., in a round table. The 'monitor' program currently supports only
Opus and PCM, though CODEC2 is on the list.
The KA9Q 'radio' program
The heart of the ka9q-radio package is the program 'radio', an
interactive general coverage receiver. It reads raw I/Q data multicast
by a SDR front end, sending tuning and gain adjustments as
needed. radio's output is a mono or stereo PCM audio multicast
stream.
If audio compression is needed, a separate 'opus' module transcodes
PCM to Opus. I.e., it receives PCM, compresses it with Opus and
multicasts it to a different IP address. This lets listeners and
players select compressed or uncompressed audio by merely joining the
corresponding multicast group.
A simple but entirely usable textual interactive user interface is
provided. If desired, it can be disabled entirely with all parameters
given instead on the command line (e.g., in shell scripts).
Architecture
The 'radio' program accepts a generic I/Q (complex) sample stream
multicast by a computer with a direct conversion ("zero IF") SDR front
end. At present, only the AMSAT UK Funcube Pro+ dongle is supported
with the 'funcube' module. The (mostly higher) sample rates produced
by other receivers such as the SDRPlay and RTL-SDR are supported but
only the Funcube's 192 kHz sampling rate has actually been tested.
An I/Q stream at 192 kHz with 16 bit samples is a constant 6.5 Mb/s
network load; this is no problem for modern Ethernet but it should be
kept away from inexpensive WiFi base stations and public Internets.
(More on problems with multicast and WiFi in the end notes).
Hardware Artifact Removal
Although a SDR front end is typically direct conversion, the complete
ka9q receiver is actually a dual-conversion superheterodyne: the first
LO and mixer are in analog hardware and the second LO and mixer are in
software. The first mixer is the quadrature (I/Q) type that produces a
complex first IF centered on zero Hz and extending from -Fs/2 to
+Fs/2, where Fs is the A/D sample rate. For the Funcube dongle, Fs =
192 kHz so the IF extends 96 kHz above and below the first LO
frequency. (For a complex signal, the Nyquist rate is equal to the
bandwidth; for a more familiar real signal, the Nyquist rate is twice
the signal bandwidth.)
This is often called a "zero IF" architecture but this is a slight
misnomer. The actual first IF can be anywhere between -Fs/2 and +Fs/2
provided it contains the entire signal bandwidth, though the 10 kHz
near each edge from a Funcube dongle is best avoided because of
imperfect anti-alias filtering before the A/D converters.
There is also a "DC spike" at 0 Hz from crosstalk from the first LO to
the receiver input. The first processing step in 'radio' completely
removes this spike, but reciprocal mixing produces some low frequency
phase noise that cannot be removed. With the Funcube dongle this noise
is only noticeable in without antenna noise covering it up, but it is
still best avoided. E.g., the range from +48 kHz to +51 kHz (or -51
kHz to -48 kHz) might be selected for SSB with a 3 kHz bandwidth.
This is still an extremely low IF by usual standards as adequate image
rejection cannot be provided by ordinary filtering. The use of complex
I/Q signals allows the frequency image to be cancelled with digital
signal processing. This requires the 'radio' program to compensate for
any slight gain and phase imbalances between the I and Q channels, and
this is its second processing step. Typical values for the Funcube
dongle might be 0.07 dB of gain imabalance and 0.4 degrees of phase
error.
Frequency conversion
The third step is to convert the first IF signal to baseband, i.e., 0
Hz. This is performed by the second (software) LO and mixer in complex
arithmetic, which suppresses the unwanted image in the other half of
the IF. The LO and mixer each require only one complex multiply per
sample. Sine and cosine calls are needed ony when the LO is retuned.
Another LO and mixer are optionally used for open-loop correction of
satellite Doppler shift. The 'radio' program reads velocity and
acceleration from an external program, calculates and applies the
appropriate frequency offset and rate.
Filtering and Demodulation
The baseband signal is filtered with fast correlation. With complex
signals, the passband can be asymmetric, e.g., +100 to +3000 Hz
selects upper sideband (USB) and -100 to -3000 Hz selects LSB. A
post-detection frequency shift is provided for CW; this is equivalent
to retuning the radio while simultaneously sliding the filter to keep
the signal at the same point in the passband. Modes other than SSB
typically use filters centered on 0 Hz but this is not required; the
edges can be individually varied, e.g. to suppress adjacent channel
interference.
The filtered baseband signal is then fed to one of three demodulators:
'AM', 'FM' and 'linear.'
The AM detector implements ordinary noncoherent envelope detection of
AM signals.
The FM demodulator handles narrowband frequency or phase modulation.
Two submodes are provided: 'FM', with a high pass cut on the received
audio below 300 Hz to remove PL/CTCSS tones and a standard -6
dB/octave audio de-emphasis above 300 Hz. The 'FMF' mode is straight
FM without post-detection filtering. Both modes use an FFT to measure
PL/CTCSS tone frequencies to 0.1 Hz accuracy. SNR, frequency offset
and peak deviation are also measured and displayed.
The 'linear' detector is used for all other modes, including SSB/CW,
ISB (independent sideband) and raw I/Q. In linear mode the filter
directly feeds the output: both the I and Q channels for stereo modes
and just the I channel for mono. Stereo is implied by I/Q and ISB and
is optional for CW/SSB, where it provides an interesting effect
because of the 90 degree phase shift (Hilbert transform) between the
channels. This may be useful to minimize fatigue during long
contests.
The I/Q and ISB modes are the same except that in ISB the filter
processes the positive and negative frequency components to force the
lower sideband onto the I (left) channel and the upper sideband onto Q
(right).
A PLL and mixer can track a carrier for coherent (synchronous) AM
detection, which is usually less noisy than regular AM envelope
detection. In "calibrate" mode the PLL can adjust a TCXO offset
estimate to bring the carrier to exactly 0 Hz. This is useful for
automatic calibration of the SDR TCXO against WWV/H, CHU, an ATSC
(North American digital TV) pilot carrier, or an external frequency
reference.
A squarer can be inserted in the PLL to track the suppressed carrier
in DSB-AM and BPSK.
User Interface
The 'radio' program has a textual user interface that uses the
"ncurses" library; it may look primitive by 2018 standards, but it is
lightweight, simple and very efficient over slow Internet paths. The
'h' key toggles a list of the supported commands. The textual user
interface can also be completely disabled and all receiver parameters
given on the command line, e.g, for invocation from a shell script.
Startup files are stored in ~/.radiostate (i.e., the directory
".radiostate") in the user's home directory). Invoking 'radio' with
the name of a startup file loads its settings. The state of the radio
can be saved to a state file with the 'w' key. On normal termination
the radio state is also stored as "default". It will be automatically
loaded on the next invocation if no explicit name is given.
The various operating modes are specified in
/usr/local/share/ka9q-radio/modes.txt. Each entry specifies a
demodulator along with filter parameters, the post-detection frequency
shift, AGC responses and option flags. For example, "USB" selects the
"linear" demdulator, a filter passband of +100 to +3000 Hz, a zero
post-detection frequency offset, an AGC attack rate of -50 dB/sec, an
AGC recovery rate of +6 dB/sec, an AGC hang time of 1.1 seconds and
mono output.
The text mode interface provides the following status windows:
The "Tuning" window shows the radio, LO and IF frequencies. If Doppler
correction is active, it is also shown here. The user can change
frequency with the arrow keys, a Griffin PowerMate USB knob, a mouse
wheel, or with text entered through a popup menu.
The "Signal" window shows signal, noise and SNR estimates at various
points in the signal path. Levels are in dBFS, i.e., decibels below
full scale (A/D saturation) as there is no way to know the gain ahead
of the A/D converters without careful calibration, which is invariably
frequency dependent.
The "Info" window shows, if available, the name of the channel or
frequency band and, if it's a ham band, the allowed emissions and
required license class. This information comes from
/usr/local/share/ka9q-radio/bandplan.txt.
The "Filtering" window gives the pre-detection filter and
post-detection frequency shift settings. The filter edges, frequency
shift and Kaiser window beta parameter can be adjusted in the same way
as the tuning. Smaller betas give sharper filters but poorer
stop-band attenuation; larger betas give wider transition bands
but better rejection outside the passband. [See the later discussion
about sample rates and decimation.]
The "Demodulator" window shows mode-specific information. The AM and
linear modes include a simple fast-attack, slow decay AGC for SSB
(more work can be done here).
The "Options" window selects the various options for the "Linear"
demodulator.
The "SDR Hardware" window shows the A/D sample rate, TCXO offset,
nominal tuner frequency, analog gain settings and gain and phase
imbalance estimates.
The "Modes" window allows the operating moded to be conveniently selected
with a mouse click.
The "I/O" window gives information on the I/Q input and PCM audio
output network streams: IP addresses or host names; port numbers;
packet, sample and error counts; and a SDR timestamp useful when
playing back recorded I/Q data. It also estimates the true I/Q sample
rate against the local computer time-of-day clock.
A "Debug" area at the very bottom of the screen shows version information
and various test and debugging messages.
Textual user input entered through popup menus; for example a tuning
frequency can be directly entered as "147m435" (147.435 MHz), 760k
(760 kHz) or 1g296296 (1296.296 MHz). If no units letter is used, a
'best guess' is made to produce a valid frequency; e.g. 14313 will
give 14.313 MHz, not 14.313 kHz (which is below the Funcube's range).
Other ka9q-radio Modules
Other modules provide either miscellaneous functions or begin more
complex planned features. None of them have especially complex user
interfaces; most take only a few command line arguments and can run as
background daemons.
'Funcube'
The 'funcube' module takes I/Q data from a locally connected Funcube
Pro+, multicasts it over the local LAN and accepts unicast commands to
tune the radio and set analog gain levels. It will also automatically
change gain levels to avoid A/D saturation. Similar modules will be
written for other SDR front ends such as the SDRPlay and RTL-SDR that
will either talk directly to the hardware or through "shimware" such
as SoapySDR.
'IQrecord' and 'IQplay"
The 'iqrecord' and 'iqplay' modules perform the functions suggested by
their names. 'iqrecord' accepts multicast I/Q and PCM audio streams
and writes them to disk. Gaps in the multicast stream due to lost
packets or silence suppression are seeked over in the recordingq to
maintain the
correct sample count and playback timing.
I/Q streams are written into files named as 'iqrecord-xxxxxx-n' where
xxxxxx is the RTP SSRC (Stream Source Identifier) and 'n' is a number
incremented to avoid overwriting existing recordings. PCM streams are
written as 'pcmrecord-xxxxxx-n'. Both files are written as raw,
headerless 16-bit PCM with all meta information in extended file
attributes.
Most but not all modern file systems support extended attributes; a
notable exception is Microsoft's VFAT32 often used as a
least-common-denominator for file exchange between different operating
systems. Warning! Many file copy and archiving utilities do not
preserve extended attributes, at least not by default.
I/Q and PCM recordings have many uses. An I/Q recording preserves
everything fed to the 'radio' input regardless of modulation type or
bandwidth (provided it fits within the receiver passband). This is
useful for testing and for demonstrating the 'radio' program when an
antenna is not available.
I/Q recordings are especially useful as backups during events
difficult or impossible to reproduce, such as a satellite pass or
balloon flight. When made at or close to the SDR hardware they depend
only on the antenna, SDR hardware and I/Q multicast program
(e.g. 'funcube'). This can guard against bugs (or the outright
failure) of more complex elements in the downstream signal path, e.g.,
a digital data demodulator. After the demodulator is fixed, the
recording can be played back to recover the data.
'iqrecord' is an excellent example of multicasting's versatility; it
can just sit quietly in the corner recording the same I/Q data stream
being processed by a real-time software receiver or telemetry decoder
without impairing its function in any way.
The 'iqplay' module plays back I/Q recordings (only -- no PCM support
at present) using the metadata contained in the external file
attributes. It can also read a raw stream from standard input to
simulate SDR front end hardware.
'Opus'
The 'opus' module was described earlier as an optional "transcoder"
that accepts uncompressed PCM (either mono or stereo) and produces a
lower bit rate compressed version with the Opus codec. Options include
a range of blocksizes from 2.5 milliseconds to 120 ms. The larger
blocks are useful only to reduce packet rate and header overhead; they
provide no additional compression and are supported only by more
recent versions of the Opus library. The default is 20 ms, which is
long enough to give good compression but short enough to be
essentially unnoticeable.
The compressed output data rate is specified by a command line
parameter; it defaults to 32 kb/s which produces surprisingly good
audio even on stereo music.
The Opus codec also supports a VOX-like "discontinuous" mode well
suited to half-duplex push-to-talk amateur operation. When silence is
detected, it automatically drops to sending "comfort noise" at only 3
packets per second.
"Packet"
This module is my first digital demodulator module for the ka9q-radio
package. It accepts PCM audio from the 'radio' program and demodulates
and decodes standard 1200 bps AX.25 frames using the ancient Bell 202A
AFSK modem. The decoded AX.25 frames are multicast in UDP packets that
do not currently have RTP headers; this will probably change. The
decoded frames can also optionally be displayed on the
console. Otherwise the module can run as an unattended daemon.
"APRS"
This unfinished module accepts decoded AX.25 frames from the "packet'
module, extracts APRS position data from a selected station, computes
the azimuth, elevation and range to that station from a specified
point, and commands antenna rotors to point at the transmitting
station. This was written to automatically track high altitude
balloons.
Footnotes and Sidebars
Sample Rates and Decimation
The I/Q input sample rate must be an integer multiple of the 48 kHz
audio output rate. Decimation is performed as a byproduct of the fast
correlator used for pre-detection filtering. Since the input FFT in a
fast correlator executes at the input sample rate, CPU loading will
increase. Faster and simpler decimators are in the works.
By default the filter decimates the Funcube 192 kHz A/D input sample
rate by a factor of 4 to a 48 kHz audio output. Other SDR front ends
with higher sample rates will require correspondingly higher
decimation ratios. Although 48 kHz may seem excessive for
communications-grade audio, I don't recommend reducing it. 48 kHz is
supported by nearly every audio D/A, and it still uses only 0.154% of
a gigabit Ethernet link.
More importantly, the Opus codec strongly prefers 48 kHz stereo even
for narrowband mono voice, and there seems to be no advantage to mono
or a lower sample rate (i.e., the compressed data rate is not reduced
nor is audio quality improved at a given rate.) So if the audio bit
rate is a concern, just use Opus; don't reduce the PCM sample rate.
Digital demodulators are best run on computers with fast local network
connections to the radio program so they can be given uncompressed
PCM. (Audio compression works by eliminating signal components
inaudible to the human ear, but which may be very important for a
digital demodulator.)
Filter Tradeoffs
Simultaneously improving both filter rolloff and stop-band attenuation
requires a longer FIR impulse response, which implies greater latency
and somewhat increased CPU loading. Currently, the filter blocksize
and FIR length can only be specified on the command line or in the
startup file, i.e., they cannot be changed without restarting the
program. (Note: the length of the FFT executed by the filter is equal
to the sum of the blocksize and FIR length minus one. The default
blocksize of 3840 corresponds to 960 samples after 4:1 decimation to
48 kHz; this is the number of samples in a 20 ms Opus frame. 3840 +
4353 - 1 = 8192, i.e., the FFT has 8k points. While the FFTW package
can handle any number of points, a power of 2 is more efficient. I've
found the default parameters to be suitable for most purposes.)
Correcting Fractional-N Frequency Synthesizer Artifacts
Because the first LO in the Funcube dongle is an analog hardware with
the usual synthesizer tuning artifacts, it is retuned only when
necessary to contain the desired signal in the first IF, i.e., between
-Fs/2 and +Fs/2. Otherwise tuning is with the second (software) LO
because it can be smoothly and instantly tuned without any
glitches. This is especially important with open-loop Doppler
correction.
Like most modern radios, the Funcube uses fractional-N frequency
synthesis with inherent restrictions on the actual set of frequencies
that can be produced. Although its programming interface advertises 1
Hz steps, the actual tuning step size varies with frequency; in the HF
and VHF range it is 1000/2048 = 0.48828 Hz so it cannot produce exact
1 Hz frequency steps.
The 'radio' program works around this in two independent ways. First,
the hardware synthesizer programming formulas and constants from the
Funcube firmware are used to determine the actual frequency for any
requested frequency so the discrepancy can be corrected by the second
LO. Second, only frequencies that the synthesizer can exactly produce
are selected; the step size varies with frequency so the worst
(largest) value of 125 Hz is always used, with the difference again
absorbed by the second LO. Although these two fixes are specific to the
Funcube dongle, other SDRs undoubtedly have the same problem subject
to the same workarounds -- if I can get the necessary details.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180421/bafa0bd2/attachment.html>
Type: text/markdown
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180421/bafa0bd2/attachment.bin>
