Ron Economos
w6rz at comcast.net
Sun Apr 8 11:46:36 PDT 2018
I have one. I'll be doing some phase noise testing with 5.6 GHz down
conversion soon.
On 04/08/2018 03:57 AM, Mike Seguin via Ground-Station wrote:
> Anyone on the list working with the Lime LMS8001a Companion Board?
> Mine finally arrived and I'm starting to work with it. So far 10 GHz
> TX/RX is working (10.368 GHz). 10 MHz lock works well.
> Next is to try 5 GHz.
> At this point, no real measurements - just seeing signals going in/out
> and learning the setup.
> After initial sectional tests, I want to set it up as 5 GHz TX and 10
> GHz receive.
