Mike Seguin
Sun Apr 8 03:57:54 PDT 2018
Anyone on the list working with the Lime LMS8001a Companion Board? Mine
finally arrived and I'm starting to work with it. So far 10 GHz TX/RX is
working (10.368 GHz). 10 MHz lock works well.
Next is to try 5 GHz.
At this point, no real measurements - just seeing signals going in/out
and learning the setup.
After initial sectional tests, I want to set it up as 5 GHz TX and 10
GHz receive.
Mike, N1JEZ
