[Ribbit-Developers] linux/command-line/desktop ribbit version
W4CKX
W4CKX at pekt.org
Fri Mar 8 04:24:16 PST 2024
Hello Robert.
Thank you for your interest in Ribbit
Let me direct you to the newest code:
You should start with Ribbit code, not Rattlegram, because Rattlegram was
the tech demo and the learnings were turned into Ribbit with significant
improvements.
Ribbit code is about 1 year newer than Rattlegram.
It is in the ORI GitHub repository.
It's C++
Before you release, we still need need to implement a shuffle.
Pierre W4CKX
On Thu, Mar 7, 2024, 11:30 PM Robert Meier via Ribbit-Developers
<ribbit-developers at lists.openresearch.institute> wrote:
> Is there a linux command line version of ribbit? [not yet]
> Who is currently working on such?
> Could you use help?
> I'm a linux guru, and mathematician.
> I usually use firefox, python/c++/java .
> If there is not already a linux command-line version,
> I might be able to package/derive/write one.
> Starting from rattlegram-1.12.tar.gz (unless someone has a better
> suggestion), I plan to wrap as rpm with c++, java, and/or python.
> Any suggestions, or (dis)recommend appreciated,
URL: <http://lists.openresearch.institute/pipermail/ribbit-developers-openresearch.institute/attachments/20240308/d868b42b/attachment.htm>
