[Ribbit-Developers] Packet format
Ahmet Inan
xdsopl at gmail.com
Tue Jul 25 22:47:28 PDT 2023
Hi Josh,
Yes, a cached WASM website would be nice but it always fails in the wrong
moment ..
I did some experiments early to see if this technology can be used instead
of mobile development:
https://www.aicodix.de/example3/
It does work nice, and we also have WebUSB, so we can do some fancy things
with an RTL-SDR dongle:
https://www.aicodix.de/example8/
Unfortunately it is still not as efficient and convenient as a native app.
If you want to play with the idea, the complete source code and a Makefile
can be found at those links, so you can start experimenting.
The new Ribbit modem scheme still needs rigorous testing before we can
start relying on it.
If you want an offline, command line modem, checkout the ribbit branch here:
https://github.com/aicodix/modem/tree/ribbit
Ahmet
On Tue, Jul 25, 2023 at 11:03 PM W4CKX via Ribbit-Developers
<ribbit-developers at lists.openresearch.institute> wrote:
> Hello Josh,
> Thank you for reaching out
> The message header metadata is being defined. It's not finalized and won't
> be until we get extensive real world testing.
> In an emergency, the situation would be cellular denied with limited to no
> connectivity. So wouldn't MQTT be reliant on having an Internet network
> running?
> Remember that the nodes (user radios) are loosely connected on ad-hoc
> transmissions.
> I hear your feedback on PWA apps.
> I am curious to learn:
> Does a PWA app allow access to the phone audio in/out microphones,
> speakers, line mic in, line out?
> And this reliably across phone makes and models?
> Pierre W4CKX
> On Tue, Jul 25, 2023, 3:12 PM Josh Datko via Ribbit-Developers
>> Is the packet binary format published somewhere?
>> I just discovered ribbit and there are some things that I can probably
>> help with. I'm not a mobile developer, but once a minimodem like utility
>> exists where the audio is converted into the packet (is it literally just
>> text? no header etc...?) there are some fun experiments perhaps.
>> For example, I'm not sure you completely have to re-invent the ARES
>> message board idea. MQTT, with perhaps carefully crafted topics could meet
>> your requirements I think. Additionally, I've always been interested in
>> having multiple radios (hams have plenty of them in general) where you
>> could map them to MQTT topics. So perhaps there is one well know uplink
>> frequency, but perhaps several downlink frequencies (different radios or
>> perhaps scanning).
>> In any case, I'm useless on mobile development but I'm interesting in the
>> more embedded / backend stuff.
>> Lastly, I'd suggest you consider a Progressive Web App (PWA) instead of
>> an actual mobile app. The benefit is you can distribute the app without the
>> app store (useful for emergencies), they are installed like regular apps,
>> and you then really only need to maintain one code base vs ios and android
>> specific features.
>> I tried it quickly and it does amazing work very nicely with two
>> handhelds and FM, but they were only 1 meter apart :P
>> Josh
URL: <http://lists.openresearch.institute/pipermail/ribbit-developers-openresearch.institute/attachments/20230726/2fe9b057/attachment.htm>
