Paul Williamson paul at mustbeart.com
Fri Mar 8 18:58:06 EST 2019
This has been posted to
https://github.com/phase4ground/documents/blob/master/Papers_Articles_Presentations/Papers/P4G%20Testbed%20Proposal.md
As always, comments are welcome.
Phase 4 Ground System Testbed Prototyping Scheme Proposal
2019-03-08 Paul Williamson, KB5MU, paul at mustbeart.com
The Phase 4 Ground project has had a reasonably well-defined top-level
system architecture  for several years now. So far, work has mainly
concentrated on some of the known "hard parts", such as DVB-S2/X
reception including the LDPC decoder, dual-band feeds, and 5 GHz power
amplifiers. Now it's time to build a testbed that approximates the
planned system architecture so that we can demonstrate and experiment
with some of the other interesting parts of the system.
The specific goal of this document is to plan a set of incremental
steps that can take us smoothly from a fresh start to a testbed system
that implements and/or simulates all the main parts of a complete
Phase 4 Ground system. Each step should be "easy" in the sense that no
major new development work is required and it is reasonably clear what
needs to be done. This will mean that some interesting parts of the
system have to be dummied out or grossly simplified. For example, the
part of the payload that multiplexes the data from all the received
uplinks is complicated, but it can be temporarily replaced by a simple
round-robin multiplexer that doesn't support features like
authentication and authorization. It will also mean that some
performance parameters of the desired system will have to be
compromised. For example, we want to be able to receive enough
channels of uplink data to effectively utilize the entire 10 MHz of
the 5 GHz Amateur Satellite Service uplink band, but to accomplish
this may require a higher-performance (presumably FPGA-based) receiver
solution than we have ready at this time. However, a receiver
subsystem that can handle just a few channels is within reach.
Once the testbed system is in place, we hope it will serve in two main ways.
First, a testbed system that resembles the desired system architecture
should make a very effective demonstration. This will make it much
easier to communicate the design and get the community excited about
its possibilities. It should contribute to recruiting more volunteers
to work on the project, and it should make our story for fundraising
much more convincing.
Second, a testbed system can serve as a platform for development of
the more advanced subsystems that haven't yet been fully worked out.
It should make it easier to identify requirements for these
subsystems. When prototype subsystems become available, it should be
possible to integrate those prototypes into the testbed and perform
some level of testing on those subsystems.
System Architecture Review
The system architecture assumes a single central payload and many user
stations. The central payload may be aboard a geosynchronous satellite
or may be at a terrestrial site with good coverage. We adopt the
satellite nomenclature and call the user station a "ground" station.
The link from the ground station to the central payload is called the
"uplink" and the link from the central payload to the ground stations
is called the "downlink".
The downlink is a single broadband transmission in the well-defined
industry standard format DVB-S2 or S2X for satellite systems.
Terrestrial systems may use DVB-S2/X as well, or may use the DVB-T2
standard instead for better performance in the multipath environment.
The downlink is shared among all the active ground stations at any
given time. This is done by treating all user signals as generic
digital data and incorporating that data into the DVB signal according
to the industry standard for Generic Stream Encapsulation (GSE).
When DVB-S2/X is used commercially, the various user data streams
(video or data) are generally transmitted over the Internet or other
data links to a large central ground station. These links are not
covered by any particular DVB standard. The central ground station is
then responsible for multiplexing the signals according to proprietary
business rules, and creates one big data stream on the ground. The
central station then transmits this big data stream as a DVB-S2/X
signal and uplinks it to the satellite payload. The satellite payload
is typically kept as "dumb" as possible, and merely retransmits the
uplinked DVB-S2/X signal on the downlink.
This common commercial architecture does not translate well to amateur
radio. There is (as yet) no robust amateur infrastructure for relaying
data to a central station. Some entity would have to operate the
central ground station, which would be expensive, politically fraught,
and probably not very fun. Worse, the central ground station would be
a fragile single point of failure for the system. Instead, the P4G
architecture places the multiplexing function in the payload, on board
the satellite in the case of a space-based system.
With the multiplexing function in the payload, P4G needs a
standardized way to pass data on the uplink from ground stations to
the payload. This needs to be relatively simple, since the payload
(which has restrictions on size, power, and complexity) must be able
to receive and process many of these signals simultaneously. We have
not identified any industry standard that is suitable for this type of
service, so P4G is defining its own uplink. The basics are that each
ground station transmits a separate MFSK carrier in one (or more, for
higher data rates) of about 100 non-overlapping uplink channels of
about 100 kHz each. The ground stations and the payload cooperate to
determine which channel may be used by each ground station, and when.
Channel-sharing parameters will be broadcast by the payload in
overhead messages in the downlink. Other overhead messages will convey
in real time which channels are in use, and by which stations, and
establish a common timebase for channel assignments. A protocol will
be specified by which a ground station may be required to authenticate
its identity and be checked against authorization policies set by the
payload operator. Development of these details into a rigorous
protocol specification is one of the major development activities
remaining.
A ground station receives the entire multiplexed downlink, but is
probably not capable of or interested in making use of all the data on
the downlink. It will want to select one or more of the multiplexed
data streams for further processing. For example, if the ground
station is participating in a roundtable voice conversation with
several other ground stations, it will want to process the data
streams from each of the the other participants. Perhaps it will
decode audio from every stream and mix the audio together for the
local user's headphones. If it can't decode that many audio channels
simultaneously, or if the local user doesn't want that, it may
implement a smart algorithm to decide which audio channel(s) to decode
and present. Similar considerations apply to other types of data
streams. Except for certain mandatory control messages transmitted by
the payload itself, the ground station is free to decode and process
as much or as little of the downlink as it chooses.
Simplifying Assumptions
In order to make the demo more visually comprehensible, and to
restrict the complexity of any one component for the testbed system,
the payload, ground station transmitter, and ground station receiver
will be implemented in three separate subsystems. In some cases the
station functions will be further divided into multiple sub-subsystems
for convenience. The ground station transmitter and/or ground station
receiver subsystems may be replicated to create a more elaborate and
capable demonstration testbed. When it's time to test protocols that
involve both the uplink and the downlink, ground station transmitters
may be interconnected one-to-one with ground station receivers in
order to create a complete ground station.
Within the scope of this plan, we won't try to implement any channel
allocation protocol, authentication, or authorization. That work does
need to be done, though.
Within the scope of this plan, we won't try to simulate the
earth-space-earth or terrestrial channels in any detail. We'll use
attenuators to match signal strengths, but won't simulate any fading
or noise or delay or Doppler shift. Those might be interesting things
to add in later phases.
We will use some simple packets and Opus encoded voice for the tests
and demonstrations. That's only a tiny representative slice of the
possible applications.
The plan is written for DVB-S2/X, but there's no particular reason why
a similar plan wouldn't apply as well to a DVB-T2 system.
Proposed Testbed Development Phases
Each of these phases is intended to be simple and incremental, and
includes a demo that exercises the function(s) implemented in that
phase. Some of the demos are just sanity checks for the lab, while
others would make good public demonstrations.
First, we will concentrate on the ground station receiver side.
Phase 1. Set up a Raspberry Pi with audio output to a speaker. This
will be the beginning of a ground station receiver.
Demo: play an audio file from the Raspberry Pi's local storage.
Phase 2. Configure the Raspberry Pi to listen to Ethernet for a
multicast IP stream containing Opus-encoded digital audio. This can be
implemented using the existing program VLC.
Demo: on a laptop, use existing tools like opusenc and multicat to
transmit a multicast IP stream via Ethernet. Play an audio file from
the laptop's disk (or use a live microphone) and hear it come out of
the Raspberry Pi's speaker.
Phase 3. Add the SR-1 (commercial DVB-S2/X receiver with GSE
capability) to the system. Connect its data output port to the
Raspberry Pi's Ethernet. On a fast laptop (NOT connected to the
Ethernet) run the GSE+DVB-S2 transmit flowgraph in GNURadio Companion
(as already demonstrated at GNURadio Conference 2018) through a USRP
B210 SDR. This is the beginning of the payload transmitter. Connect
the SDR's RF output through suitable attenuators to the SR-1's RF
input. Again run opusenc and multicat, either on the fast laptop or on
another laptop, and arrange networking interconnects (like we did at
GNURadio Conference) so that the multicast IP stream goes over the
GSE+DVB-S2 link.
Demo: again transmit Opus-encoded voice and hear it come out of the
Raspberry Pi's speaker, after passing over the air in DVB-S2 GSE
format.
Phase 4: Modify the transmit flowgraph by adding a simple frame mux at
the input to the GSE module. One input of the mux gets the multicast
IP packet stream from the Opus encoder, as before. Other inputs stream
from file sources or, optionally, from other multicast IP packet
streams from other computers.
On the Raspberry Pi, wrap VLC in a simple UI that allows a user to
select which of several multicast IP addresses to monitor.
Demo: show that the Raspberry Pi can switch around among the multiple
audio streams at will.
Phase 5: Add additional copies of the Raspberry Pi.
Demo: show that multiple streams can be received in parallel. We are
of course faking the multiple reception to some extent, since all the
Raspberry Pis are listening to the same SR-1. The SR-1 has powerful
enough hardware to handle the entire downlink.
Partial success can be declared here. We've demonstrated a multiplexed
downlink over GSE and a minimal ground receiver with the ability to
select and receive one of the streams. Since we're using Opus at a
decent bit rate, the audio quality ought to be outstanding. This might
be a good time to set aside the downlink and work on the downlink, but
there's still more to do on the downlink.
Phase 6: Add our open-source DVB-S2/X receiver (perhaps it is a
flowgraph) running on suitable hardware. Split the RF signal between
the SR-1 and our receiver. Split the Ethernet into two segments, each
with one or more of the Raspberry Pis. Let the SR-1 continue to feed
one segment and let our receiver feed the other segment.
Demo: as before. Show that the open source receiver works like the
SR-1. Adjust the downlink attenuators and see how the performance
compares near the threshold. Now the demo is less fake, since we have
two completely separate receivers.
Phase 7: Replicate the DVB-S2/X receiver and connect each one
separately to its own Raspberry Pi.
Demo: as before, but even less fake
Phase 8: Incorporate the functions of the Raspberry Pi into the
hardware that's running the DVB-S2/X receiver.
Demo: as before, but with less clutter
Set that aside and start on the uplink. This could also be started in
parallel, resources permitting.
Phase A. Set up a fast laptop with GNU Radio. This will be the
beginning of the payload receiver. Create a simple flowgraph that
implements a polyphase filter bank to receive 4 contiguous 100 kHz
channels. Connect each of the four output channels to spectrum
visualizers. Connect another SDR (perhaps the USRP X310) to the
flowgraph as a signal source. Connect an off-the-shelf signal
generator's output to the SDR's RF input.
Demo: Run the flowgraph and observe the four channels of vacant
spectrum. Manually sweep the signal generator across the band, and
watch the carrier sweep across each of the four spectrum visualizers
in turn.
Phase B: Set up a separate SDR with GNU Radio on a laptop. This will
be the beginning of the ground station transmitter. Create a flowgraph
that alternates a fixed synchronization preamble with a packet data
source, and transmits it in a MFSK burst (i.e., turning the
transmitter on, sending a preamble and some data, and then turning it
off). Feed it with random data packets for now. Make it transmit near
the middle of one of the four channels the polyphase filter bank is
receiving, and connect its RF output through suitable attenuators to
the RF input of the payload receiver SDR (removing the signal
generator).
Demo: See the bursts of data in one of the spectrum visualizers on the
payload receiver.
Phase B1: Try replacing the ground station transmitter laptop with a
Raspberry Pi. If it works we can more cheaply and conveniently
replicate multiple ground stations for later testing.
Demo: same as Phase B.
Phase C: Modify the flowgraph in the payload receiver to add a MFSK
demodulator and a correlation detector on each of the four outputs of
the PFB. Add a time visualizer at the output of each correlation
detector.
Demo: See the transmitted preambles cause a pulse on the corresponding
time visualizer.
Phase D: Modify the payload receiver flowgraph to use the correlation
sync pulse to parse the data burst into a header of N bits and a body
of M bits. Add a data display widget that shows the header and another
data display widget that shows the first bits of the body.
Demo: See that the first N bits of the random packet data shows up the
header widget and the next few bits of the random packet data shows up
in the body widget.
Phase E: Modify the ground station transmitter flowgraph to encode a
header and body. Define certain bits of the header to be a length
field. Add a UI widget to set the length field. Modify the payload
receiver flowgraph to parse out the length field from the header and
display it.
Demo: Set various values in the length field on the ground station
transmitter, and see them show up in the length display on the payload
receiver.
Phase F: Modify the ground station transmitter flowgraph to accept a
packet input, determine its length, pack that value into the length
field of the header, and use the data from the packet to fill the body
part of the transmission.
Demo: send various length packets into the ground station transmitter
flowgraph, and see that the length display on the payload receiver
shows the same lengths.
Phase G: Modify the payload receiver flowgraph to use the received
length value to grab that much of the received body data and output it
as a packet. Use Wireshark to monitor the packet output.
Demo: Send packets from the ground station transmitter and see them
appear in the Wireshark display.
Phase H: Combine the payload receiver flowgraph with the multiplexed
GSE+DVB-S2 (payload transmitter) flowgraph from Phase 4. Have the
packets that were output in Phase G go into the multiplexer instead.
Move the Wireshark to monitor the ground station receiver's Ethernet.
Demo: send packets from the ground station transmitter and see them
appear in the Wireshark display, after going over DVB-S2.
Phase I: Move the opusenc+multicat source to the ground station
transmitter's Ethernet. Arrange for the multicast IP stream to go into
the packet transmitter.
Demo: transmit Opus-encoded voice and hear it come out of the
Raspberry Pi's speaker, after passing through both the uplink and the
downlink.
Phase J: Replicate one or more copies of the ground station transmitter.
Demo: transmit multiple streams of Opus-encoded voice and receive them
on the multiple ground station receivers from Phase 5.
That's already a pretty nice demo. Since we have physical separation
between the ground station transmitter, the payload, and the ground
station receiver, we can label them and point to them and make the
demo visually compelling. We have all the major components of the
system, albeit in simplified form.
Going beyond the demo scope, some next steps might be:
Phase K: Replace the multiplexer in the payload flowgraph with a
custom block. Have it generate an on-the-fly status report and
transmit that on its own multicast IP stream, muxed in with the user
streams. Add a process to the ground station receiver to accept the
status report stream and display it.
Demo: see the system status live on the ground station receiver.
Phase L: Add a block in the payload flowgraph to generate an overhead
information stream and feed it to the multiplexer. Add a process to
the ground station receiver to accept the overhead stream and display
it.
Demo: see the system overhead information on the ground station receiver.
Phase M: Modify the payload flowgraph to alternate long transmissions
at the regular MODCOD as before with short transmissions of canned GSE
data at the most robust MODCOD.
Demo: increase the attenuation on the downlink RF until the regular
MODCOD can no longer be received. Note that the SR-1 still locks up on
and receives the robust MODCOD. This simulates initial ground station
acquisition. Note that the SR-1 is not designed for burst reception,
so the "short" transmissions may have to be rather long for this demo
to work.
Phase N: If we have reached Phase 6 on the downlink side, modify the
DVB-S2/X receive flowgraph to handle the MODCOD switching back and
forth, if necessary.
Demo: as in Phase M, only with our own DVB-S2/X receiver.
Phase O: (maybe this makes sense) Modify the DVB-S2/X receiver to take
advantage of information and synchronization obtained from the robust
MODCOD to improve acquisition performance at the regular MODCOD. Maybe
it would help if the information sent under the robust MODCOD included
the index of the regular MODCOD.
Demo: vary the attenuation on the downlink RF and see if our receiver
can now acquire the downlink at a lower signal strength, or more
quickly.
In Conclusion
This plan doesn't finish the project. It does plan substantial forward
progress, and creates specific and effective public demonstrations.
