KENT BRITAIN wa5vjb at flash.net
Fri Jan 25 18:41:07 EST 2019
 Hi David
The plan is for most to use a $15 xtal controlled satellite LNB.
Output from the LNB is about 700 MHz for the 10 GHz signal.
So you could use either a broad band receiver that tunes the 700 MHzband, or an SDR that covers 700 MHz for your receiving equipment.
The Octagon LNB's are stable enough to listen to 10,368 MHz SSB signals.
You probably would not want to use it with the typical DSS dish.  Way too muchgain to track the satellite.   I'm looking at options using a small dish, or a horn.
Hey, and only $15 or so!!!
73 Kent WA5VJB
    On Friday, January 25, 2019, 5:33:19 PM CST, David Vieira via Ground-Station <ground-station at lists.openresearch.institute> wrote:
  Michelle - Thanks for posting.  I'll frame some of the questions.
Typical 10 GHz terrestrial contesting rigs are Heterodyne; that is a Mixer works with a Local Oscillator (LO) to take the RF down to an IF (Intermediate Frequency).For an SDR, that IF can be digitized by an Analog-Digital Converter.
The most popular IF for contesting/SSB rigs is 144 MHz.  For a data BW of 10 MHz that may or may not be a fast enough IF carrier.  If we can digitize and recover the data, it would allow a lot of re-use of existing equipment.
I've heard suggestions/proposals up to the 1.2 GHz Ham band.In some sense, the IF carrier could be 144/220/440/915/1200 MHz, or even any Non-Ham frequency in between.
There are a lot of proof of existence designs for a 10 GHz Mixed down to an IF; and lots of off the shelf ADC dev-boards.  (catch me off thread for details).
Some questions I have are:  ---from an FPGA side of the SDR, what data rate(s) can the FPGA absorb in to a decimator?
Must we decide upfront on a single frequency; or preferably allow flexibility in the RF front end design (ie, Mixer, PLL and Local Oscl hardware choices) by allowing a wide and programmable variety of ADC and decimation rates?
{This is where RF and Digital folks must communicate across walls.}  ;-)
Comments welcome.
regards,DavidKI6CLA
What are our options?
Ground-Station mailing list
URL: <http://lists.openresearch.institute/pipermail/ground-station/attachments/20190125/07c2fb96/attachment.html>
