[Ground-station] 10GHz Remote Receiver
Mike Seguin n1jez at burlingtontelecom.net
Sat Jun 2 06:43:33 EDT 2018
A nice step up in antenna gain from the naked feed horn is the MTI Flat
panel antenna. These show up on eBay now and then. I use one of the 25
ish dBi gain ones with an Avenger LNB strapped right to the back of the
panel.
They are not as sharp as a dish, so pretty easy to point.
They will take a few watts of transmit power as well.
Spec sheet attached.
They also make a version good at 5.7 GHz which I also have down in the shop.
Mike, N1JEZ
Name: 10 GHz MTI Wireless flat panel.PNG
URL: <http://lists.openresearch.institute/pipermail/ground-station/attachments/20180602/7004cbda/attachment-0001.png>
