[Ground-station] EVE/EME update and call for participation
Tue Apr 28 08:05:07 PDT 2026
Greetings all!
For the upcoming inferior conjunction of Venus and Earth, there is a
growing community of amateurs that are bound and determined to get a
communications signal bounced off Venus and received here on Earth. This is
EVE. The inferior conjunction is when Venus and Earth are the closest
together.* This is the right time to attempt this feat, and it happens only
once every 18 months or so.
The channel is daunting. So, me and my crew at ORI, SBMS, and others, have
put together a link analysis.
Everything can be found at https://github.com/OpenResearchInstitute/EVE
This includes the current link analysis Jupyter Notebook, all the support
files to make it run, and more. Such as, all the documents used to propose
observing sessions at the "really big" dishes at Green Bank and Effelsberg.
What can we do now to help make good things happen?
We have a modulation and coding scheme designed especially for this
channel.
But we need to test it BEFORE Venus whooshes by in October of 2026. We need
to test it now. We've tested in simulation, sure, but we all know that's
not good enough.
We need to test it with the Moon. EME is a close enough channel. It doesn't
have the same Doppler spread that Venus has, because the Moon is "locked"
to the Earth, but it does wiggle around a bit, and it is a very hard
microwave channel.
Want to help? Have you been waiting for a reason to build an EME station?
Wait no more.
What do you need to do? Build a station capable of EME. Be able to send an
arbitrary digital waveform (IQ modulation from SigMF files) and be able to
receive it. We need a lot of data here.
EME stations are so fun. We want 1299.5 MHz (1296 MHz will do) and 2304
MHz. I'm building a 2304 MHz station.
What will happen if we're successful? We dramatically improve our chances
to do the first ever communications over EVE. We've been able to bounce a
carrier wave (radar return) off of Venus twice. Once in 2009 and once in
2025. Let's move things forward.
The communications protocol itself is of interest as well. It's not just a
low SNR type of deal. The Doppler spread, from the rotation of Venus, is
kind of a drag. This exact type of thing, bouncing a signal off a rotating
surface, is some of the most difficult things to deal with in digital
communications. For Venus, the left side of the planet is moving away from
us. The right side of the planet is moving towards us. We illuminate the
entire planet, so our signal is warped when it bounces back to us.
We can deal with this. This is something that digital communications folks
generally avoid, because it wrecks the signal. But, we have a solution.
Let's try it with EME and find out if we're right.
Are you in? Let me know, and welcome aboard.
-Michelle Thompson W5NYV
ORI
* The inferior conjunction is when Venus and Earth are aligned with respect
to the Sun, when Venus and Earth are on the same side of the Sun. The
superior conjunction is when the Earth, Venus, and the Sun are all in a
line, and Venus and Earth are on opposite sides of the Sun. Because of
elliptical orbits, Venus and Earth are actually not the closest together at
the inferior conjunction! Being closest together is what we want, for
radio. The actual closest approach is within three days of the inferior
conjunction. All of this is documented in the proposals and link analysis.
What comes out of looking at this data, is that we have several weeks of
very good opportunities, and not just a short window. Multiple bites at the
Venus Apple, while it's near us, have every chance of succeeding.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20260428/70c7c6b1/attachment.htm>
