[Ground-station] Planar antennas
Jordan Trewitt jmtrewitt at gmail.com
Tue Jan 30 09:49:51 PST 2024
Isn't this the same technology that ThinKom uses on their VICTER antennas
they have one platter that changes azimuth, another for elevation and
another for changing between LHCP and RHCP. It seems like they're only
really good for X-band to E-band just reading their brochures about their
individual antennas and phased arrays for their gateway antennas.
-Jordan
On Wed, Feb 5, 2020, 18:37 KENT BRITAIN via Ground-Station
> Do you see any large metamaterial lens out front?
> If so it would be nearly as thick as it is wide.
> Very different technology.
> On Wednesday, February 5, 2020, 5:25:39 PM CST, Daniel Zeleznikar <
> daniel.zeleznikar at gmail.com> wrote:
> Sounds similar to this tech... is it the same?
> https://www.thinkom.com/technology/
> On Wed, Feb 5, 2020 at 2:59 PM KENT BRITAIN via Ground-Station
> A Concept drawing.
> Much easier ways of doing it and it completely leaves out
> the logic systems necessary to control it.
> Kent WA5VJB
> On Wednesday, February 5, 2020, 3:39:17 PM CST, KC9SGV via Ground-Station
> Maybe this is old news...
> https://www.mq.edu.au/__data/assets/pdf_file/0011/556805/MQ-2015016-Planar-High-Gain-Antennas-with-Variable-Beam-Directions.pdf
> Bernard,
> KC9SGV
> Sent from my iPad
> Dan Zeleznikar
> (216) 233-6232
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20240130/ea6d1ae1/attachment.htm>
