[Ground-station] GNU Radio Help Needed: OreSat Team (time sensitive!)
Glenn LeBrasseur
gleb2 at pdx.edu
Thu Jan 4 14:42:38 PST 2024
Roland,
We will review these ideas.
Your first point is actually one of our next steps, putting only a single
transmit path into its own flowgraph, since that is primarily where the
problem lies.
Thanks for the suggestions,
Kind regards,
Glenn
Glenn N. LeBrasseur, P.E.
glennl at pdx.edu
On Thu, 4 Jan 2024 at 00:32, Roland Turner <roland at rolandturner.com> wrote:
> Glenn,
> I am absolutely not a GR expert, but I wonder whether you aren't missing
> opportunities to materially simplify the graph that you're asking GR to
> plumb, doing which might allow to avoid the problem if not properly fix it:
> - Are you able to split the TX and RX paths into separate processes?
> This is unsatisfying, but the less complicated a task you're asking GR to
> do, the fewer weird things are likely to happen.
> - Are you able to remove *all* of the not strictly necessary blocks?
> e.g. you've not mentioned a Lime device in your setup, but there are
> LimeSuite blocks. Presumably they're not being scheduled any CPU time if
> the device is not physically present, but why rely on that assumption when
> it's in your power to remove it?
> - Does removing file and GUI sinks avoid the problem? If you, how many
> of those can you live without?
> - Etc.
> - Roland
> On 4/1/24 16:25, Glenn LeBrasseur via Ground-Station wrote:
> Michelle,
> This is the flowgraph in question:
> https://github.com/uniclogs/uniclogs-sdr/blob/maint-3.10/flowgraphs/OreSat0.grc
> We have a different repo organization for our ground station work.
> I can also send our testing notes if you like.
> Thanks so much,
> 73,
> Glenn
> On Wed, 3 Jan 2024 at 13:28, Michelle Thompson via Ground-Station
>> Greetings all,
>> Please read the message below from our friends at OreSat and speak up if
>> you can work with them to diagnose the problem preventing a clean handoff
>> on 11 January.
>> OreSat's public repository is here: https://github.com/oresat
>> OreSat's 0.5 website is here: https://www.oresat.org/satellites/oresat0-5
>> There are quite a few repositories in GitHub. Glenn, would you please
>> point out where the problematic flowgraphs are?
>> -Michelle
>> Glenn LeBrasseur <gleb2 at pdx.edu>
>> Tue, Jan 2, 3:16 PM (21 hours ago)
>> to me, Andrew
>> Hey Michelle,
>> If you, or you have anyone who you know who is knowledgeable with GNU
>> Radio and is willing to help us with an odd buffering problem, we would be
>> totally appreciative.
>> Our team here at OreSat is having a bit of an existential crisis
>> regarding GNU Radio. We are using a HackRF One for transmit and a RTL-SDR
>> for receive, to send our fairly simple GFSK traffic through our ground
>> station, and we are having packet buffering problems. The flow graph
>> communicating through UDP sockets is behaving strangely when sending the
>> packets. At first things were fine when our packets were small, but now
>> varying the packet size, ever so slightly, is causing things to go wrong.
>> We are totally willing to share our flowgraphs and testing procedure, as
>> you know we are totally open source, so they currently are online at our
>> GitHub site. We will tell you everything we are doing!
>> Anything you could help with would be great, particularly since we are
>> doing integration testing right now of our OreSat 0.5 cubesat, for a
>> handoff on 11-Jan-2024, and this has just cropped up.
>> Please let me or Andrew know what's possible.
>> Kind regards and 73,
>> Glenn, KJ7SU
>> gleb2 at pdx.edu
>> glennl at pdx.edu
> Glenn Noel LeBrasseur
> glenn.lebrasseur at gmail.com
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20240104/a640c9f5/attachment-0001.htm>
