[Ground-station] Weekly Report for 5 August 2022 - tons going on!
Fri Aug 5 12:44:16 PDT 2022
# Project Report
Additions and corrections? Submit a pull request or send them in via email.
## FPGA
### DMA read/write problem with the Encoder solved
FPGA meetup video recording can be found here: https://youtu.be/r2Mbz-XQCCc
We have been battling a problem with our DVB-S2 encoder block.
The repository that integrates the reference design from ADI and our
encoder can be found here:
https://github.com/phase4ground/adi_adrv9371_zc706
The hdl-as-submodule branch has re-arranged the repository as a set of
submodules instead of static directories.
Reads and writes from the Zynq processor were not happening correctly. The
team pulled together and didn't give up and the problem is now solved. The
root cause was with the memory map. Thank you to Evariste, Anshul, Suoto,
Leonard, and Ken for taking the time to fix this. We now know how to add
the next custom block in a way that will avoid this issue. We also now know
how to better use the integrated logic analyzer. We've also documented the
process of going from HDL git clone to processor-side application.
https://github.com/phase4ground/documents/blob/master/Remote_Labs/Working-With-FPGAs.md
`check out the zc706-petalinux-Vitis branch to see the documentation`
A pull request for this branch of the documentation has been made, so it
should show up as "mainline" instructions shortly.
### Transmit with Encoder
MQTT, as pioneered by Evariste on his implementation on the PLUTO, looks
like a great way to go. Anshul is taking this on and we'll back him up in
Remote Lab West.
In order to use the ADRV9371, we generate sample code from the Transceiver
Evaluation Software from ADI. This provides configuration settings for a
particular frequency and bandwidth for the transceiver, in either C or
Python. From this starting point, we will write the transmit application
code. We have already run TES successfully, but integrating the large
number of settings produced and making sure the transceiver is behaving
properly is a non-trivial milestone. If you have experience here please
review our work.
### Downlink Receiver
Codebase updates in progress. Ahmet Ihnan is the lead.
## Haifuraiya
We will propose an open source amateur radio HEO satellite project to
JAMSAT. We are grateful for the opportunity and look forward to their
review.
Successful project kickoff, slide deck review, and the publishing of an
annotated video recording of the work session all happened this past week.
https://youtu.be/wMaDHsPUhLw
## Uplink
Demonstration of our uplink protocol Opulent Voice working over the air can
be seen here: https://youtu.be/i7k-jKtU_n8
## Aqua-Phage
Letter requesting permission to submit a grant proposal to the FDA
(required as per their process) was sent this week. The funding opportunity
sought is for a conference on bacteriophage in aquaculture, specifically
fish farming.
## DEFCON - Imminent!
### DEFCON Demonstrations and Presentations by Open Research Institute at
RF Village
#### Opulent Voice
Opulent Voice is an open source high bitrate digital voice (and data)
protocol. It's intended to be useful for both space and terrestrial
deployments. We’re getting nice clear 16kbps OPUS audio out of the
demodulator. See and hear a demonstration at the ORI exhibit in RF Village.
We’ll be using COBS protocol within Opulent Voice. If you’re unfamiliar
with COBS, please read about it here:
https://en.wikipedia.org/wiki/Consistent_Overhead_Byte_Stuffing
Authentication and authorization is built in and optional. There is no
separate “packet mode”. Things are designed to “just work” and get out of
your way whether or not you’re sending voice or data.
Based on Mobilinkd codebase that implemented M17, the Opulent Voice
development implementation can be found here:
https://github.com/phase4ground/opv-cxx-demod
Authentication and Authorization functions will be summarized in a poster
presentation. Find out more about this work here:
https://github.com/phase4ground/documents/tree/master/Engineering/AAAAA
#### Ribbit
Ribbit is an open source SMS data mode that leverages smart phone hardware.
The free Android app produces digital audio that you transmit over your HT
or any other audio coupled device. There will be a poster explaining the
architecture and you can pick up a Ribbit sticker with QR code for the free
Android app at ORI's exhibit in RF Village.
#### Regulatory
Interested in being able to do more with open source satellites? We have
some landmark regulatory results that solve a big problem for those of us
in the US that have wanted to do open source satellite work without fear.
See our poster in RF Village and find out more at the following link:
https://github.com/phase4ground/documents/tree/master/Regulatory
#### OpenRTX
OpenRTX is a team based in Italy that specializes in open source firmware
for a variety of platforms in the VHF/UHF digital voice world. They work on
DMR and M17 implementations for the MD-380, and more. Pick up a business
card and see a demonstration of OpenRTX's work at ORI's exhibit in RF
Village.
#### Tiny CTF
We'll have the World's Smallest Wireless CTF! Come and find it and get a
mission patch if you're successful.
#### More!
There's plenty more. If you see a Volcano and friendly people, you've found
the right place.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20220805/eb02a8e8/attachment.htm>
