Tue Sep 22 11:16:02 PDT 2020
Thank you - very much looking forward to seeing them.
On Tue, Sep 22, 2020 at 11:12 AM Bruce Perens <bruce at perens.com> wrote:
> I'm going to visit the big one in the warehouse and take some photos.
> On Tue, Sep 22, 2020, 11:09 AM Michelle Thompson <
>> Let's talk a bit more about this.
>> It's in Berkeley, CA, and you have two of them.
>> Could you describe what's involved? We can post a PDF with the model
>> number.
>> On Tue, Aug 4, 2020 at 7:20 PM Bruce Perens <bruce at perens.com> wrote:
>>> I have two Lindgren RF anechoic chambers with power filters and I think
>>> a USB filter dating back to the original slow USB. The larger one is about
>>> the size of the pallet it's on, square, and crushed the plastic pallet with
>>> its weight. I would contribute that one to the project if we can find a
>>> place where it would be accessible, and can truck it from Berkeley
>>> Warehouse. There is a forklift at the warehouse to put it on a truck, it's
>>> definitely going to need one to take it off.
>>> Thanks
>>> Bruce
>>> On Tue, Aug 4, 2020, 6:53 PM Michelle Thompson via Ground-Station
>>> <ground-station at lists.openresearch.institute> wrote:
>>>> Resources are caught up. Teams are next.
>>>> -Michelle W5NYV
>>>> On Tue, Aug 4, 2020 at 9:02 AM Michelle Thompson <
>>>>> Thanks Keith,
>>>>> Working on a staff and resources repository today.
>>>>> -Michelle W5NYV
>>>>> On Tue, Aug 4, 2020 at 8:06 AM Keith Wheeler <
>>>>> keith.m.wheeler at gmail.com> wrote:
>>>>>> In PDX I have access to:
>>>>>> Creality Ender 3d printer
>>>>>> K40 (small) 40W CO2 laser
>>>>>> Small engraving machine
>>>>>> Small sheet metal brake
>>>>>> Hydraulic hand terminal crimper 10 through 0/1 gauge
>>>>>> Additionally I own but do not currently have access to:
>>>>>> Large Smithy 3in1 mill/drill/lathe
>>>>>> Metal bandsaw
>>>>>> Metal chopsaw
>>>>>> Lincoln MIG welder
>>>>>> 20 ton hydraulic press
>>>>>> Hydraulic tubing bender
>>>>>> Sheet metal bead roller
>>>>>> Throatless shear
>>>>>> Numerous rivet, nutcert, cleco, etc tools
>>>>>> Numerous hand fabrication tools: flangers, tubing flare formers,
>>>>>> etc
>>>>>> Numerous taps, dies, end mills, ball mills, specialty bits
>>>>>> Router table
>>>>>> Air compressor
>>>>>> Sandblast cabinet
>>>>>> Various paint guns
>>>>>> Vacuum pump
>>>>>> Composite and casting support equipment
>>>>>> Parkerizing solution/equipment
>>>>>> Small reflow oven
>>>>>> Small solder paste stencil station
>>>>>> On Mon, Aug 3, 2020 at 9:35 PM Michelle Thompson via Ground-Station
>>>>>>> Greetings all!
>>>>>>> This thread is primarily for Scott McGillivray (and other
>>>>>>> mechanically-inclined volunteers).
>>>>>>> We will be doing more mechanical design going forward. There are
>>>>>>> resources available for prototyping. This report outlines some of them.
>>>>>>> Video report here:
>>>>>>> https://youtu.be/2omYVVKAnhs
>>>>>>> Transcript:
>>>>>>> Here's a walk through of our mechanical fabrication capabilities in
>>>>>>> San Diego. If you have shop capabilities that you can offer for the Phase 4
>>>>>>> project, then please file either an issue or a pull request (or write me)
>>>>>>> and let's add to the list below!
>>>>>>> Link to document in GitHub is:
>>>>>>> https://github.com/phase4ground/documents/blob/master/Management/Weekly_Engineering_Reports/20200803_Phase4_weekly_report.txt
>>>>>>> 1) Voltera V-one circuit printer.
>>>>>>> https://www.voltera.io/product/specs
>>>>>>> This can handle ordinary PCB material up to 3mm thick but can also
>>>>>>> do flexible circuits on material like Kapton.
>>>>>>> 0.2mm minimum trace width, 0402 minimum passive size, and 128mm by
>>>>>>> 116mm print area.
>>>>>>> It can print, cure, and solder. It can also drill but I do not have
>>>>>>> that attachment.
>>>>>>> 2) Ultimaker 2 that has been upgraded to a 2+. We have done several
>>>>>>> microwave feeds and antenna designs including elliptical taper 10GHz horns,
>>>>>>> dual band feeds, helical structures, and more.
>>>>>>> We metallize using conductive paint and the results have been very
>>>>>>> good.
>>>>>>> Resolution of this printer setup is 0.02mm, which is good enough for
>>>>>>> 120GHz multi-reflector systems and beyond.
>>>>>>> 3) Wood shop with metal brake, grinding wheel, and drill press.
>>>>>>> 4) For textiles and embroidery, we have a Pfaff creative vision with
>>>>>>> embroidery deck and all the hoops. We also have a serger.
>>>>>>> 5) Multi-purpose machine, air compressors, and a 1929 South Bend
>>>>>>> Lathe.
>>>>>>> 6) This Tormach PCNC 440 is a small, light duty 3-axis CNC milling
>>>>>>> machine capable of working to accuracies of about a thousandth of an inch
>>>>>>> (a couple hundredths of a millimeter) within a work envelope of about 6 by
>>>>>>> 10 inches (150 by 250 millimeters). We have a reasonably complete set of
>>>>>>> ordinary tooling and work holding accessories for it. We are certainly not
>>>>>>> expert machinists, but with these tools we can make prototype runs of a
>>>>>>> wide variety of parts in materials like plastic, aluminum, and steel. Not
>>>>>>> every shape is easy or even possible to make with a 3-axis mill, but for
>>>>>>> most designs we can make a part that will work.
>>>>>>> 7) We have access to the large laser cutter at colab.org. Use of
>>>>>>> the machine is free for non-commercial work.
>>>>>>> As we enter into a stage where we will be doing more mechanical
>>>>>>> design, these are the resources that are immediately available for early
>>>>>>> prototypes.
>>>>>>> Thanks everyone!
>>>>>>> More soon,
>>>>>>> -Michelle W5NYV
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200922/afd95a02/attachment-0001.html>
