Tue Sep 22 11:08:47 PDT 2020
Let's talk a bit more about this.
It's in Berkeley, CA, and you have two of them.
Could you describe what's involved? We can post a PDF with the model
number.
On Tue, Aug 4, 2020 at 7:20 PM Bruce Perens <bruce at perens.com> wrote:
> I have two Lindgren RF anechoic chambers with power filters and I think a
> USB filter dating back to the original slow USB. The larger one is about
> the size of the pallet it's on, square, and crushed the plastic pallet with
> its weight. I would contribute that one to the project if we can find a
> place where it would be accessible, and can truck it from Berkeley
> Warehouse. There is a forklift at the warehouse to put it on a truck, it's
> definitely going to need one to take it off.
> Thanks
> Bruce
> On Tue, Aug 4, 2020, 6:53 PM Michelle Thompson via Ground-Station
>> Resources are caught up. Teams are next.
>> On Tue, Aug 4, 2020 at 9:02 AM Michelle Thompson <
>>> Thanks Keith,
>>> Working on a staff and resources repository today.
>>> -Michelle W5NYV
>>> On Tue, Aug 4, 2020 at 8:06 AM Keith Wheeler <keith.m.wheeler at gmail.com>
>>> wrote:
>>>> In PDX I have access to:
>>>> Creality Ender 3d printer
>>>> K40 (small) 40W CO2 laser
>>>> Small engraving machine
>>>> Small sheet metal brake
>>>> Hydraulic hand terminal crimper 10 through 0/1 gauge
>>>> Additionally I own but do not currently have access to:
>>>> Large Smithy 3in1 mill/drill/lathe
>>>> Metal bandsaw
>>>> Metal chopsaw
>>>> Lincoln MIG welder
>>>> 20 ton hydraulic press
>>>> Hydraulic tubing bender
>>>> Sheet metal bead roller
>>>> Throatless shear
>>>> Numerous rivet, nutcert, cleco, etc tools
>>>> Numerous hand fabrication tools: flangers, tubing flare formers, etc
>>>> Numerous taps, dies, end mills, ball mills, specialty bits
>>>> Router table
>>>> Air compressor
>>>> Sandblast cabinet
>>>> Various paint guns
>>>> Vacuum pump
>>>> Composite and casting support equipment
>>>> Parkerizing solution/equipment
>>>> Small reflow oven
>>>> Small solder paste stencil station
>>>> On Mon, Aug 3, 2020 at 9:35 PM Michelle Thompson via Ground-Station
>>>>> Greetings all!
>>>>> This thread is primarily for Scott McGillivray (and other
>>>>> mechanically-inclined volunteers).
>>>>> We will be doing more mechanical design going forward. There are
>>>>> resources available for prototyping. This report outlines some of them.
>>>>> Video report here:
>>>>> https://youtu.be/2omYVVKAnhs
>>>>> Transcript:
>>>>> Here's a walk through of our mechanical fabrication capabilities in
>>>>> San Diego. If you have shop capabilities that you can offer for the Phase 4
>>>>> project, then please file either an issue or a pull request (or write me)
>>>>> and let's add to the list below!
>>>>> Link to document in GitHub is:
>>>>> https://github.com/phase4ground/documents/blob/master/Management/Weekly_Engineering_Reports/20200803_Phase4_weekly_report.txt
>>>>> 1) Voltera V-one circuit printer. https://www.voltera.io/product/specs
>>>>> This can handle ordinary PCB material up to 3mm thick but can also do
>>>>> flexible circuits on material like Kapton.
>>>>> 0.2mm minimum trace width, 0402 minimum passive size, and 128mm by
>>>>> 116mm print area.
>>>>> It can print, cure, and solder. It can also drill but I do not have
>>>>> that attachment.
>>>>> 2) Ultimaker 2 that has been upgraded to a 2+. We have done several
>>>>> microwave feeds and antenna designs including elliptical taper 10GHz horns,
>>>>> dual band feeds, helical structures, and more.
>>>>> We metallize using conductive paint and the results have been very
>>>>> good.
>>>>> Resolution of this printer setup is 0.02mm, which is good enough for
>>>>> 120GHz multi-reflector systems and beyond.
>>>>> 3) Wood shop with metal brake, grinding wheel, and drill press.
>>>>> 4) For textiles and embroidery, we have a Pfaff creative vision with
>>>>> embroidery deck and all the hoops. We also have a serger.
>>>>> 5) Multi-purpose machine, air compressors, and a 1929 South Bend
>>>>> Lathe.
>>>>> 6) This Tormach PCNC 440 is a small, light duty 3-axis CNC milling
>>>>> machine capable of working to accuracies of about a thousandth of an inch
>>>>> (a couple hundredths of a millimeter) within a work envelope of about 6 by
>>>>> 10 inches (150 by 250 millimeters). We have a reasonably complete set of
>>>>> ordinary tooling and work holding accessories for it. We are certainly not
>>>>> expert machinists, but with these tools we can make prototype runs of a
>>>>> wide variety of parts in materials like plastic, aluminum, and steel. Not
>>>>> every shape is easy or even possible to make with a 3-axis mill, but for
>>>>> most designs we can make a part that will work.
>>>>> 7) We have access to the large laser cutter at colab.org. Use of the
>>>>> machine is free for non-commercial work.
>>>>> As we enter into a stage where we will be doing more mechanical
>>>>> design, these are the resources that are immediately available for early
>>>>> prototypes.
>>>>> Thanks everyone!
>>>>> More soon,
>>>>> -Michelle W5NYV
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200922/8c2658c0/attachment-0001.html>
