Ron Economos
w6rz at comcast.net
Mon Mar 23 12:33:34 PDT 2020
Back of the napkin calculation suggests that the gateway could be offset
from the Moon by up to 10 degrees. Can the pattern be that oval?
On 3/23/20 10:52, KENT BRITAIN via Ground-Station wrote:
> Hi Michelle
> I wouldn't rule out a dish/feed that puts out an Oval pattern much like
> the FAA RADARS. Now pointing at the moon would be enough.
> Tips of the oval to match the satellite's max distance from the moon.
> Kent WA5VJB
> On Monday, March 23, 2020, 12:46:03 PM CDT, Michelle Thompson via
> Thank you Zach, super helpful. I am really looking forward to seeing
> what your students can achieve. Is anyone at the point where they
> would be interested in a teleconference or recording a ~15 minute
> video presentation?
> It's clear from simply drawing the orbit in my notebook based on Frank
> Bauer's presentations that simply tracking the moon will result in too
> much loss over the week it takes for Gateway to zip around the moon
> (at microwave). We assumed we'd need to track, but getting real
> numbers means the link budgets and antenna assumptions get more real.
> GMAT is up and running and I'm working through tutorials. They're well
> done! GMAT has a MATLAB and python interface.
> I learned about Poliastro at the Open Source Cubesat Workshop. See
> more about it here: https://docs.poliastro.space/en/stable/
> On Mon, Mar 23, 2020 at 9:42 AM Leffke, Zachary via Ground-Station
> Hi Michelle and Everyone!
> We need FOSS tools for this sort of thing for both mission
> analysis and design as well as for tracking programs for the
> Amateur Radio community. SGP4 and TLEs from celestrak aren’t
> going to cut it for this kind of mission. Pointing ‘at the moon’
> is probably not going to be sufficient for Gateway, especially
> with tighter microwave beams and the NRHO of the Gateway. I am
> unfamiliar with GMAT, and encourage as many folks as possible to
> look into it as Michelle mentioned. I just wanted to let folks
> know that I am pulling a couple parallel threads related to the
> Gateway and modelling its orbit.
> Thread 1 (mission modelling, nearer term). AGI’s STK (not FOSS)
> and a few VT AOE students.
> I mentioned in a previous thread that we have a senior AOE student
> working on building models in STK for Lunar Gateway (with help
> from two grad students). That is progressing fairly well (despite
> all the remote work / COVID-19 isolation) and we expect the
> student to be finished by end of the semester with a basic model
> that we can build upon. For those that aren’t aware, System’s
> Tool Kit (STK) is a powerful orbital/trajectory modelling tool
> from Analytical Graphics Incorporated (AGI) and includes tools
> like a communications toolbox for modelling antenna patterns,
> transmitters, receivers, performing link analysis, etc. etc. It
> also has the ‘astrogator’ tool which is a required package for
> modelling the orbits/trajectories for things that are a bit more
> complicated than SGP4 and LEO/MEO/GEO. The downside of STK is
> that it is hyper-expensive for individual users. We are fortunate
> at VT to be part of the AGI academic partnership and have access
> to the Pro version (with the comms toolbox), and the Lunar Gateway
> problem is a good learning experience for students. GMAT is widely
> considered to be the open source alternative to STK, but for the
> moment I’m sticking with what I know and have access to. Perhaps
> results can be compared from one to the other in order to double
> check ourselves once things are a bit more ‘ripe.’
> Thread 2. Open Source Tools – Python, NAIF (SPK files), and JPL
> HORIZONS
> I am currently playing around with a python package called
> Skyfield (https://rhodesmill.org/skyfield/) that is a follow on to
> the popular pyephem module. For modelling major bodies (planets,
> moons, etc.) Skyfield uses ephemerides from NASA/JPL in the form
> ‘.bsp’ files. More specifically it uses a subset of SPICE files
> from NASA’s NAIF group (https://naif.jpl.nasa.gov/naif/), which is
> a defined format for modelling a LOT of things related observation
> geometry in the solar system. The ‘bsp’ files used in skyfield
> are actually Type 2 and/or Type 3 SPK files in the SPICE system
> (out of 21 possible Types), that it accesses through a separate
> module called ‘jplephem’. To over-simplify it a bit, think of
> SPKs as containing the coefficients for various regressions of
> trajectory/orbit data that is derived from spacecraft tracking
> data (like ranging from DSN). The different ‘Types’ of SPKs are
> related to what kind of regression and form of the equation is
> used (Chebyshev polynomials, Lagrange interpolation, Hermite
> Interpolation, etc.). Skyfield reads in the coefficients, sets up
> the equations, you feed it a time, it pumps it through the
> equation returns a position, and then computes the ‘additional
> info’ most users are interested in (like az, el, range, range
> rate). Related, but slightly different from SPICE SPK files is
> the JPL HORIZONS database (https://ssd.jpl.nasa.gov/horizons.cgi),
> which contains a number of ephemerides for comets, asteroids,
> planets, and a large number of spacecraft in the Solar System.
> HORIZONS can be queried through a web interface and/or a telnet
> interface, and there is a python package called Astroquery that
> provides a python API for access (via the telnet interface).
> HORIZONS can provide observational data (think az, el, range,
> range rate), state vector information (think time series of
> position and velocity), and/or orbital elements. I am currently
> trying to figure out how to merge the two and get HORIZONS to
> export an SPK of various Spacecraft (currently using LRO as the
> ‘standin’ for Gateway). HORIZONS definitely exports SPKs, but at
> the moment it looks like only for asteroids and comets and in a
> type that is not currently supported by Skyfield. The ultimate
> goal is to be able to import a non-Earth Orbit spacecraft into
> Skyfield as a ‘body’ so that the rest of the code would flow like
> normal. As an alternative…(though a hack in my current opinion,
> might change) skyfield can be ‘bypassed’ and HORIZONS can be
> directly queried for observer data.
> I would encourage folks to take a look at the skyfield github page
> (https://github.com/skyfielders/python-skyfield/) and look for
> some of the issues related to this. Contributing to Skyfield
> supporting various SPK types might go a good ways towards FOSS
> tools for tracking non-earth orbiting vehicles (like gateway…..or
> for use in an ‘Amateur DSN’ context). Also, generating SPKs for
> spacecraft from the HORIZONS database data ultimately for use with
> Skyfield (and other tools) is also a good way to help…there is
> another python module called SpiceyPy
> (https://pypi.org/project/spiceypy/) that can be used to create
> SPKs. Assuming Gateway data shows up in HORIZONS (or on the NAIF
> site), this could be the alternative to Celestrak/Space-Track for
> where Hams go to get data for tracking spacecraft not in Earth
> Orbit. Eventually there may need to be an alternative site set up
> (maybe ORI, maybe AMSAT) where just the SPKs can be downloaded,
> maybe produced from HORIZONS data, to alleviate strain on the
> HORIZONS telnet interface (not sure what the limits are here).
> Finally, I should also mention that SPICE files have support in
> multiple languages, not just Python (see the NAIF link above for
> more details), but again, I’m sticking with the tool I know for
> now. SPKS can also be used in GMAT. At the end of the day….SPK
> files seem to be the way the ‘pros’ do it, maybe we should
> consider it ourselves.
> All good stuff! GMAT should definitely be explored for mission
> modelling and analysis purposes. At VT we’re trying to get a
> handle on STK modelling for the same purpose. Personally, I’m
> looking into Skyfield+Python+NAIF+HORIZONS for ultimate
> application in ‘real time tracking’ programs (to feed antenna
> controllers, Doppler tuning, etc.). Can ‘gpredict’ (and popular
> windows equivalents) be modified to include this type of
> tracking? I encourage as many folks as possible to start thinking
> about this and these kinds of questions and either jump in on
> what’s already going on or come up with other ways to do it.
> -Zach, KJ4QLP
> Research Associate
> Aerospace & Ocean Systems Lab
> Work Phone: 540-231-4174
> Cell Phone: 540-808-6305
> *From:*Ground-Station
> <ground-station-bounces at lists.openresearch.institute> *On Behalf
> Of *Michelle Thompson via Ground-Station
> *Sent:* Sunday, March 22, 2020 1:52 PM
> *To:* Michelle Thompson via Ground-Station
> *Subject:* [Ground-station] Gateway update + Gateway orbit modeling
> Things are moving on Gateway (lunar station)!
> I’m trying to find an orbit model so we can make progress on a
> ground station design. JAMSAT asked for help at AMSAT-NA Symposium
> and I said yes. We’ve been talking ever since and are at the stage
> of writing formal commitments to AREx, the project from ARISS that
> is working to put amateur radio on the Gateway.
> Yes, I know, everything could be canceled or delayed. But, the
> work we’re doing is entirely re-usable and is exactly in line with
> our payload project.
> I have not yet found a published orbital model for Gateway, but
> from the meetings and presentations and documents, I know it’s a
> near rectilinear halo orbit with a 7 day period. It’s highly
> elliptical, going from 3,000 (wikipedia) or 7,000 (Frank Bauer)
> out to 70,000 km. I am trying to get clarification on the perilune
> (closest distance to moon).
> I have GMAT from NASA successfully installed and over 1000 pages
> of documentation to go along with it.
> I don’t know anything about modeling orbits other than what I
> learned in AP Physics in high school, but I’m willing to try to
> get something nailed down and reviewed enough to help us with 1)
> tracking 2) link budgets and 3) antenna repercussions.
> Plus, surely an animation of what things look like would be super
> fun and help everyone spread the word about this really neat
> amateur radio opportunity.
> So if you know anything about GMAT and can answer some newbie
> questions (as soon as we have some) please speak up. If you're
> interested in installing it and trying to help with this, then go
> here and get it stood up on your machine:
> https://sourceforge.net/projects/gmat/
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200323/264de113/attachment.html>
