Keith Wheeler
keith.m.wheeler at gmail.com
Tue Aug 4 08:06:21 PDT 2020
In PDX I have access to:
Creality Ender 3d printer
K40 (small) 40W CO2 laser
Small engraving machine
Small sheet metal brake
Hydraulic hand terminal crimper 10 through 0/1 gauge
Additionally I own but do not currently have access to:
Large Smithy 3in1 mill/drill/lathe
Metal bandsaw
Metal chopsaw
Lincoln MIG welder
20 ton hydraulic press
Hydraulic tubing bender
Sheet metal bead roller
Throatless shear
Numerous rivet, nutcert, cleco, etc tools
Numerous hand fabrication tools: flangers, tubing flare formers, etc
Numerous taps, dies, end mills, ball mills, specialty bits
Router table
Air compressor
Sandblast cabinet
Various paint guns
Vacuum pump
Composite and casting support equipment
Parkerizing solution/equipment
Small reflow oven
Small solder paste stencil station
On Mon, Aug 3, 2020 at 9:35 PM Michelle Thompson via Ground-Station
> Greetings all!
> This thread is primarily for Scott McGillivray (and other
> mechanically-inclined volunteers).
> We will be doing more mechanical design going forward. There are resources
> available for prototyping. This report outlines some of them.
> Video report here:
> https://youtu.be/2omYVVKAnhs
> Transcript:
> Here's a walk through of our mechanical fabrication capabilities in San
> Diego. If you have shop capabilities that you can offer for the Phase 4
> project, then please file either an issue or a pull request (or write me)
> and let's add to the list below!
> Link to document in GitHub is:
> https://github.com/phase4ground/documents/blob/master/Management/Weekly_Engineering_Reports/20200803_Phase4_weekly_report.txt
> 1) Voltera V-one circuit printer. https://www.voltera.io/product/specs
> This can handle ordinary PCB material up to 3mm thick but can also do
> flexible circuits on material like Kapton.
> 0.2mm minimum trace width, 0402 minimum passive size, and 128mm by 116mm
> print area.
> It can print, cure, and solder. It can also drill but I do not have that
> attachment.
> 2) Ultimaker 2 that has been upgraded to a 2+. We have done several
> microwave feeds and antenna designs including elliptical taper 10GHz horns,
> dual band feeds, helical structures, and more.
> We metallize using conductive paint and the results have been very good.
> Resolution of this printer setup is 0.02mm, which is good enough for
> 120GHz multi-reflector systems and beyond.
> 3) Wood shop with metal brake, grinding wheel, and drill press.
> 4) For textiles and embroidery, we have a Pfaff creative vision with
> embroidery deck and all the hoops. We also have a serger.
> 5) Multi-purpose machine, air compressors, and a 1929 South Bend Lathe.
> 6) This Tormach PCNC 440 is a small, light duty 3-axis CNC milling machine
> capable of working to accuracies of about a thousandth of an inch (a couple
> hundredths of a millimeter) within a work envelope of about 6 by 10 inches
> (150 by 250 millimeters). We have a reasonably complete set of ordinary
> tooling and work holding accessories for it. We are certainly not expert
> machinists, but with these tools we can make prototype runs of a wide
> variety of parts in materials like plastic, aluminum, and steel. Not every
> shape is easy or even possible to make with a 3-axis mill, but for most
> designs we can make a part that will work.
> 7) We have access to the large laser cutter at colab.org. Use of the
> machine is free for non-commercial work.
> As we enter into a stage where we will be doing more mechanical design,
> these are the resources that are immediately available for early
> prototypes.
> Thanks everyone!
> More soon,
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20200804/872f33ba/attachment.html>
