    Thu Sep 26 16:24:00 PDT 2019
There are solar panels.
>From https://ambasat.com/ambasat-2/ambasat-1/
"AmbaSats are just a little bigger than the size of a couple of postage
stamps but have solar cells, a LoRaWAN radio transceiver..."
For the dashboard, there's a big hint here:
"Your AmbaSat-1 is fully TTN compliant so as well as viewing data in your
Dashboard, you can sign-up for a TTN account and access your satellite’s
sensor data directly using a range of different TTN extensions."
I think the dashboard is essentially The Things Network. I'll see what I
can find out about the dashboard availability.
Interesting question about HABs! I think several people on this list are
much more active than I am in designing and building payloads, and might be
able to give an evaluation based on what's on the ambasat.com website.
On Thu, Sep 26, 2019 at 11:56 AM KC9SGV <kc9sgv at gmail.com> wrote:
> The "three months in space" bit, makes me wonder.
> Maybe out of power by then ?
> (Don't see any solar panels on the board.)
> What would the possibility be to use the board as payload on a HAB (high
> altitude balloon).
> Maybe a Mylar balloon cluster achieving float, like the current Miami
> effort ?
> Then the environmental modules would make sense.
> Could you get the dashboard and web based tracking without buying the
> launch ?
> Bernard,
> KC9SGV
> Sent from my iPad
> On Sep 26, 2019, at 1:11 PM, Howie DeFelice via Ground-Station <
> It has a LoRA radio on board which is really cool. I always thought that
> LoRA on a LEO would make a great Store  and Forward messaging sat. The
> chirp spread spectrum modulation handles doppler quite well and LoRA chips
> on carrier boards are easy to find to make ground stations.  Unfortunately
> there is little chance we could license it since the FCC decided that
> anything smaller than a 1U cubesat is too small to track.
> Howie
> AB2S
> *From:* Ground-Station <
> ground-station-bounces at lists.openresearch.institute> on behalf of
> Michelle Thompson via Ground-Station <
> *Sent:* Thursday, September 26, 2019 11:26 AM
> *To:* Michelle Thompson via Ground-Station <
> *Subject:* [Ground-station] Please vote - Ambasat sensor
> I bought into the Kickstarter for Ambasat.
> <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fambasat.com%2F&data=02%7C01%7C%7C2c3f3cef695d4bdb07b208d7429697ee%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637051086889564741&sdata=HQ1maV9Z5PGG%2BUZf%2FqV5zFpH8qsFQ0WDvC4BHQkJ5rE%3D&reserved=0>
> I’d like you all to help choose the sensor!
> Choices here:
> https://ambasat.com/ambasat-2/sensor-options/
> <https://eur02.safelinks.protection.outlook.com/?url=https%3A%2F%2Fambasat.com%2Fambasat-2%2Fsensor-options%2F&data=02%7C01%7C%7C2c3f3cef695d4bdb07b208d7429697ee%7C84df9e7fe9f640afb435aaaaaaaaaaaa%7C1%7C0%7C637051086889574740&sdata=0gUbpgbQldmIxAydIuXk6fdBWaQQmBuY8yEH48Rpe64%3D&reserved=0>
> Disclaimer:
> This has nothing to do with our project. I acknowledge that Ambasat is
> controversial. No project funds are involved.
> Why post this here?
> Details:
> I asked Ambasat about a custom amateur radio payload, so we could test
> something for us. The kickstarter had that option. The lead of Ambasat said
> yes, amateur payload ok, several people I asked at Virginia Tech said go
> for it, and a small group looked at the specs and tried to design something
> useful for us. But, the very compact size and power budget was quite
> daunting. And the time frame was very short. We don’t have enough
> miniaturization or time. Instead of a custom board, we have a standard
> flight and a ground version.
> Instead of quietly sending this up, I wanted to share it with the team as
> something fun. I just received the survey for the sensors, so we easily
> have a week at least to vote. It includes some sensors already. The free
> choice is an additional sensor slot.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190926/8e086fe0/attachment.html>
