[Ground-station] Ground-Station Digest, Vol 19, Issue 18
Mon Oct 28 15:46:07 PDT 2019
If it can work, then I'm ready to fund, build, test, and promote.
Just need a circuit and a bill of materials.
On Mon, Oct 28, 2019 at 3:41 PM KENT BRITAIN <wa5vjb at flash.net> wrote:
> With the new syn chips from TI, and others, they don't take that much
> power.
> We could do a lot with 50 milliwatts or so, More up to whatever you are
> willing
> to provide to that last GaAs FET. There is a reason NASA chose X-Band for
> the deep space network. And the ground stations are cheap enough.
> Those xtal controlled LNB downconverters are only about $15.
> Kent
> On Monday, October 28, 2019, 5:23:01 PM CDT, Michelle Thompson via
> What's the minimum power we need for a 10 GHz beacon?
> On Mon, Oct 28, 2019 at 2:59 PM Thomas Parry via Ground-Station
> Hey,
> I've had a quick look at this and by my calculations you're only going to
> get 0.5 W from the solar cell at boresight. Adding the lack of maximum
> power point tracking I reckon you can only count on >250 mW for the design.
> I think this really precludes anything at 10 GHz. Anything that low power
> and low footprint will be custom silicon (or III-V). Although I would
> welcome being proved wrong.
> I'm my opinion that really pushes you into the sub-GHz option. Which
> raises the question of antennas, anything VHF will be very inefficient.
> Ideally a high UHF frequency?
> Will keep mulling it over and will have a deeper look into components.
> Thomas
> On Mon, 28 Oct 2019, 16:55 ,
> <ground-station-request at lists.openresearch.institute> wrote:
> Send Ground-Station mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> ground-station-owner at lists.openresearch.institute
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of Ground-Station digest..."
> Today's Topics:
> 1. draft Custom Sensors Inspired by AmbaSat (Michelle Thompson)
> Message: 1
> Date: Mon, 28 Oct 2019 08:52:26 -0700
> From: Michelle Thompson <mountain.michelle at gmail.com>
> To: Michelle Thompson via Ground-Station
> Subject: [Ground-station] draft Custom Sensors Inspired by AmbaSat
> Message-ID:
> CACvjz2XT19R27vXZHeuXuFpTS10-ZR7Cc5s3pPXMMp4xbBFnZw at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Here's a draft of the custom sensor document. These are ideas inspired by
> the AmbaSat project.
> Summary: beacons beacons beacons!
> I found *several* other AmbaSat people at AMSAT Symposium. Most of us have
> asked for specifications for the custom sensors and also for the custom
> board. Those specifications are still missing from this document, but I'll
> put them in when I get them.
> I've stepped up the Number of Asking Gently request level I am giving
> AmbaSat.
> If we can fill out the designs a bit then I can find funding to make
> prototypes. You never know who might fly something like a 10 GHz beacon if
> there's an easy-to-incorporate board.
> Take 15 minutes today and suggest some parts, additional sensor ideas, or
> provide feedback.
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.openresearch.institute/pipermail/ground-station/attachments/20191028/bdaee73b/attachment.htm
> A non-text attachment was scrubbed...
> Type: application/pdf
> Desc: not available
> URL: <
> http://lists.openresearch.institute/pipermail/ground-station/attachments/20191028/bdaee73b/attachment.pdf
> Subject: Digest Footer
> End of Ground-Station Digest, Vol 19, Issue 18
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20191028/dad2dbe1/attachment.html>
