[Ground-station] Es'Hail2, QO-100 success vs NA development stage.
Thu Mar 21 15:09:41 PDT 2019
Thanks for the note - I am just back from JAMSAT and was traveling and
working when this was posted. I replied on the AMSAT-DL forum.
If members of the list aren't already on it, I highly recommend you join.
Go to https://forum.amsat-dl.org/ and sign up. We fully support Phase 4A!
For both technical and humanitarian reasons, it is an outstanding
achievement. Phase 4 Ground has already benefited from observing,
measuring, and experimenting with QO-100. The success has informed our
engineering and provided inspiration and motivation for doing the difficult
DSP and coding theory work required to fully implement DVB-S2 and DVB-S2X.
On Thu, Mar 21, 2019 at 2:48 PM KC9SGV via Ground-Station
> While AMSAT-DL and QARS revel in the success of their two ham frequency
> transponders on Es'Hail 2, NA and SA still seek for an answer to the phase
> 4 quest.
> The following has been mentioned on another forum dedicated to this
> issue...
> pe1chl <https://forum.amsat-dl.org/cms/index.php?user/98-pe1chl/>
> Intermediate
> - Monday, 3:57 am
> <https://forum.amsat-dl.org/index.php?thread/202-proposal-for-an-internet-remote-base-station-irb-in-the-footprint-of-qo-100/&postID=3338#post3338>
> <https://forum.amsat-dl.org/cms/index.php?user/67-hb9ska/>
> Quote from HB9SKA
> <https://forum.amsat-dl.org/index.php?thread/202-proposal-for-an-internet-remote-base-station-irb-in-the-footprint-of-qo-100/&postID=3322#post3322>
> Look at https://www.amsat.org/?s=phase+4b [image: ;)]
> "Didn't that project come to a halt for some reason?
> I wonder if a new option would be to find some satellite that is now in
> the specification phase and is to be built by MELCO, and try to re-use the
> knowledge and experience they already gained when building the transponder
> aboard Es'hail-2.
> That could make it easier to convince the operator to do the same thing as
> well."
> Maybe the above suggestion would be the easier path to success ?
> KC9SGV
> Sent from my iPad
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190321/b33de30f/attachment.html>
