Ron Economos
w6rz at comcast.net
Fri Jan 25 16:14:21 PST 2019
I'm not sure we are talking about the same thing yet. So what exactly do
you expect to decimate and why?
On 1/25/19 16:07, Michelle Thompson wrote:
> The beginning of wisdom being the definition of terms and all, it
> would be good to make sure we're all talking about the same thing.
> So far, I've used LNBs and USRPs for receive, with the LNB doing an IF
> at 618MHz (LNB-on-a-Stick) and giving reasonable performance.
> Decimation to me is a DSP thing, or used to reduce power consumption
> when you don't need to sample as high as you can.
> On Fri, Jan 25, 2019 at 3:52 PM Ron Economos via Ground-Station
> The standard IF for DVB-S2 receivers is 950 to 2150 MHz.
> DB6NT was selling a down-converter from 10489-10500 MHz to
> 1129-1140 MHz for P4A.
> https://shop.kuhne-electronic.com/kuhne/en/shop/new/MKU+LNC+10+OSCAR+P4A/?card=1832
> I'm not sure what decimation has to do with receiving DVB-S2. The
> entire 10 MHz signal needs to be demodulated. Individual baseband
> frames will be selected for processing, but I call that
> de-multiplexing.
> Ron W6RZ
> On 1/25/19 15:32, David Vieira via Ground-Station wrote:
>> Michelle - Thanks for posting. I'll frame some of the questions.
>> Typical 10 GHz terrestrial contesting rigs are Heterodyne; that
>> is a Mixer works with a Local Oscillator (LO) to take the RF down
>> to an IF (Intermediate Frequency).
>> For an SDR, that IF can be digitized by an Analog-Digital Converter.
>> The most popular IF for contesting/SSB rigs is 144 MHz.
>> For a data BW of 10 MHz that may or may not be a fast enough IF
>> carrier. If we can digitize and recover the data, it would allow
>> a lot of re-use of existing equipment.
>> I've heard suggestions/proposals up to the 1.2 GHz Ham band.
>> In some sense, the IF carrier could be 144/220/440/915/1200 MHz,
>> or even any Non-Ham frequency in between.
>> There are a lot of proof of existence designs for a 10 GHz Mixed
>> down to an IF; and lots of off the shelf ADC dev-boards. (catch
>> me off thread for details).
>> Some questions I have are:
>> ---from an FPGA side of the SDR, what data rate(s) can the FPGA
>> absorb in to a decimator?
>> Must we decide upfront on a single frequency; or
>> preferably allow flexibility in the RF front end design (ie,
>> Mixer, PLL and Local Oscl hardware choices) by allowing a wide
>> and programmable variety of ADC and decimation rates?
>> {This is where RF and Digital folks must communicate across
>> walls.} ;-)
>> Comments welcome.
>> regards,
>> David
>> KI6CLA
>> On Friday, January 25, 2019, 2:41:54 PM PST, Michelle Thompson
>> via Ground-Station <ground-station at lists.openresearch.institute>
>> <mailto:ground-station at lists.openresearch.institute> wrote:
>> While we are striving to enable all sorts of wonderful designs by
>> putting prototypes into GNU Radio, a central goal is to design
>> our own hardware.
>> We've had a lot of progress on the protocol and algorithm front
>> (GSE, LDPC, some of the polyphase).
>> Some fundamental decisions about our own hardware need to be made.
>> When we receive, we expect to have to decimate. This is because
>> we are receiving at a relatively high frequency (10GHz).
>> Our bandwidth is (up to) 10MHz. For DVB-S2/X, we fix our sampling
>> rate, depending on what bandwidth we want to support. We have a
>> lot of freedom here.
>> Picking the right frequencies for the receive chain is therefore
>> important.
>> What are our options?
>> What options make the best sense?
>> I'd like to build and test as soon as possible, so let's get some
>> discussion going.
>> <mailto:Ground-Station at lists.openresearch.institute>
>> Ground-Station at lists.openresearch.institute <mailto:Ground-Station at lists.openresearch.institute>
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190125/e7611e33/attachment.html>
