David Vieira
dpv at ieee.org
Fri Jan 25 15:32:26 PST 2019
Michelle - Thanks for posting. I'll frame some of the questions.
Typical 10 GHz terrestrial contesting rigs are Heterodyne; that is a Mixer works with a Local Oscillator (LO) to take the RF down to an IF (Intermediate Frequency).For an SDR, that IF can be digitized by an Analog-Digital Converter.
The most popular IF for contesting/SSB rigs is 144 MHz. For a data BW of 10 MHz that may or may not be a fast enough IF carrier. If we can digitize and recover the data, it would allow a lot of re-use of existing equipment.
I've heard suggestions/proposals up to the 1.2 GHz Ham band.In some sense, the IF carrier could be 144/220/440/915/1200 MHz, or even any Non-Ham frequency in between.
There are a lot of proof of existence designs for a 10 GHz Mixed down to an IF; and lots of off the shelf ADC dev-boards. (catch me off thread for details).
Some questions I have are: ---from an FPGA side of the SDR, what data rate(s) can the FPGA absorb in to a decimator?
Must we decide upfront on a single frequency; or preferably allow flexibility in the RF front end design (ie, Mixer, PLL and Local Oscl hardware choices) by allowing a wide and programmable variety of ADC and decimation rates?
{This is where RF and Digital folks must communicate across walls.} ;-)
Comments welcome.
regards,DavidKI6CLA
What are our options?
Ground-Station mailing list
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190125/8154426e/attachment.html>
