Scotty Cowling
scotty at tonks.com
Sat Feb 2 13:11:14 PST 2019
This is a great discussion, sorry I have arrived so late in the thread.
Since I am a FPGA and a hardware guy, my comments are hardware-centric.
Probably makes me odd man out, but here goes...
I greatly favor a single ADC at a higher rate (than dual ADCs clocked in
phase or quadrature). The I and Q samples can be generated
mathematically inside the FPGA without the analog mismatch problems
associated with trying to build two identical copies of analog and ADC
hardware. The quadrature mixers are implemented in digital hardware to
whatever precision the hardware allows. Of course, there is a price to
be paid. The ADC has to run twice as fast, and wider NCOs and
multipliers use FPGA fabric and require fasted logic. Both cost $$
While the AD9361 is a fantastic part, we pay for all the features
whether we use them or not. Mixers and oscillators all add noise,
whether they are all integrated inside one chip or spread out. System
engineering is in order.
As Zach said, every decimation by 4 increases dynamic range by
approximately 1 bit. So we should sample as fast as possible, and
decimate in the digital domain. Except that ADC width and speed cost
money, and the FGPA's ability to consume and process data is limited in
speed. So we want to pick ADC width, clock speed and FPGA based on the
knee of the price-performance curve. This "knee" is always moving, which
is why today's hardware is better than yesterday's (well, usually).
My guess is that the practical, affordable ADC performance today is at
~125Msps and either 14 or 16 bits. Interestingly, affordable FPGAs can
handle 150MHZ to 200MHz at their inputs and outputs without too much
problem. Go much faster, and you get really expensive really fast. The
same with resources. I am most familiar with Altera/Intel FPGAs, so
someone with Xilinx experience can add to this. The best cost per logic
element seems to be either the MAX10M50 (50K LEs) or the Cyclone 5 E
(logic only series). The C5E goes up to 300K LEs (which is a lot, and
costs appropriately). If we want a dual-core ARM hard processor
(per-configured in silicon, using zero LEs), the Cyclone 5 SE at 110K
LEs is probably the best bet.
So where does this leave us for P4G hardware? Some kind of down
conversion at the antenna is pretty obvious. Is it better to use an off
the shelf LNB to a higher frequency (e.g., 900MHz) and then down-convert
to base band at the SDR receiver front end? Or is it better to use a
custom LNB and down convert directly to a base band frequency (say
30MHz) that can be directly sampled?
A third option would be to build a VHF or UHF direct-sampling SDR (at
900MHz, to use the above example), but I think that would be too expensive.
Scotty WA2DFI
