[Ground-station] Bidirectional IP packet radio article (hat tip to Julian KF4MOT for sharing it)
Fri Apr 19 16:17:22 PDT 2019
It will totally trash out all the stations running weak signal at 432 MHz, EME and FT8 activity.
The spreading codes are usually simple and the RF power ends up in big clumps, notevenly spread as the theory predicts.
WA5VJB
PS I was the first person to get a 2.4 GHz Direct Sequence Spread Spectrum system through
FCC compliance testing. Grantee Code LPH.
On Friday, April 19, 2019, 5:58:35 PM CDT, Steve Stroh via Ground-Station <ground-station at lists.openresearch.institute> wrote:
I advocate starting an STA like TAPR for Spread Spectrum.
On Fri, Apr 19, 2019 at 15:05 Ron Economos via Ground-Station <ground-station at lists.openresearch.institute> wrote:
Not legal in the US on 70 cm. Exceeds the limits of 56 kbaud and 100 kHz bandwidth in part 97.307(f)(6).
Personally, I think this rule should be deleted. What makes 70 cm any different than 33 cm and above?
On 4/19/19 09:28, Michelle Thompson via Ground-Station wrote:
https://hackaday.com/2019/03/30/bidirectional-ip-with-new-packet-radio/
Steve Stroh (personal / general): stevestroh at gmail.com
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20190419/4e11de12/attachment.html>
