[Ground-station] 1269 MHz
Fri Sep 7 07:28:57 PDT 2018
Certainly sounds like there is interest.
I only have a few prototypes at the moment and they are low in frequency. I needto spend some time on the antenna range. I think there is a dB or twohiding in there.
Back to work, Kent G8EMY/W5
To: aardvark at saintaardvarkthecarpeted.com
Cc: KENT BRITAIN <wa5vjb at flash.net>; Michelle Thompson via Ground-Station <ground-station at lists.openresearch.institute>
Sent: Friday, September 7, 2018 9:16 AM
Subject: Re: [Ground-station] 1269 MHz
In fact I have two Arrows, so I'll take two extensions.
73FrankAB2KT/VE7
On Fri, Sep 7, 2018 at 7:09 AM Ground-Station <ground-station at lists.openresearch.institute> wrote:
Ground-Station wrote:
> OK, this falls sort of under marketing research.
> About how many AMSAT lads have an Arrow antenna?
> How many would be interested in adding 1269 MHz to them for about $50?
> I have prototype 11 element Yagi's designed to clip on the boom of theexisting Arrow antennas. Trying to get an idea of how many to run.
> 73 Kent WA5VJB
Count me in!
Hugh Brown
http://saintaardvarkthecarpeted.com
Ground-Station mailing list
Tell me, what is it you plan to do with your one wild and precious life? -- Mary Oliver
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180907/09c40c46/attachment.html>
