[Ground-station] Microwave Update this weekend
Mike Seguin
Thu Oct 11 03:45:36 PDT 2018
I'm here. Arrived last night.
Today, Rene VE2UG and I will scout the Englewood Dam site and possibly
set up 78 GHz and make a contact. The scouting is in advance of a 134
GHz attempt on Friday morning at the Dam site with WA1ZMS.
Also today I'll scout locations in the parking lot here for the tests of
WA5VJB's L band prototype antenna. Well do that Friday probably the
12:10 pass of AO-92. It assumes KO4MA can get the bird switched to L
Band tonight.
Also, if you arrive in time, VOA Tour 2-5 PM today. Busy day today!
On 10/10/2018 1:30 PM, Michelle Thompson via Ground-Station wrote:
> Several of us will be at Microwave Update this weekend
> (http://microwaveupdate.org/) in Dayton, OH.
> I'm bringing 122GHz gear, including the Silicon Radar Easy dev boards
> and some 3D printed experimental dishes and subreflectors.
> If you're there, find us! Plenty to talk about including SatNOGS
> microwave expansion, the future of metadata with SigMF, new GOES weather
> satellite kits and software, 10GHz LNB-on-a-Stick work, and more.
Mike, N1JEZ
