[Ground-station] Fwd: [Bod] FW: [Rmg] FW: DSLWP URGENT HELP NEEDED!
Wed May 23 03:13:57 PDT 2018
Condensed it a bit and put it on Slack as well.
On Tue, May 22, 2018, 22:32 Tom Clark <tom.k3io at gmail.com> wrote:
> Just after I posted the item I also received this additional note -- Tom
> -------------------------------- Forwarded message
> > The request for help has already been posted on the AMSAT-BB earlier
> > today at 6:03 AM PDT. Message from Nico PA0DLO was:
> > After their launch on 2018-05-20 at 21:28 UTC, LJ 1 and LJ 2 were
> > maneuvered onto a track to the Moon. Several amateurs received
> > telemetry from the satellites. But now LJ 1 appears to encounter
> > problems.
> > Quoting Wei BG2BHC:
> > "Can you help to find amateurs in the US to help to monitor DSLWP-A
> > on 435.425 and 436.425 now?
> > We lost the contact of satellite A on S band after an orbit adjustment.
> > We just tried to switch on UHF, but we don't know if it works or not.
> > The sat is just above South America.
> > If it works, 435.425 should be 500bps GMSK and JT4 alternately.
> > 436.425 should be 250 bps GMSK. Both transmit once in 5 minutes.
> > Thank you very much!
> > Wei"
> > 73,
> > Nico PA0DLO
> This email has been checked for viruses by Avast antivirus software.
> https://www.avast.com/antivirus
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180523/7fba9f2d/attachment.html>
