[Ground-station] FCC Small-Satellite NPRM
Ron Economos
w6rz at comcast.net
Sun Jun 17 15:41:03 PDT 2018
No. Here are the Amateur-Satellite bands in the US.
7.0 to 7.1 MHz
14.0 to 14.25 MHz
18.068 to 18.168 MHz
21.0 to 21.45 MHz
24.89 to 24.99 MHz
28.0 to 29.7 MHz
144 to 146 MHz
435 to 438 MHz
1260 to 1270 MHz uplink only
2400 to 2450 MHz
3400 to 3410 MHz
5650 to 5670 MHz uplink only
5830 to 5850 MHz downlink only
10.45 to 10.50 GHz
24.0 to 24.05 GHz
47.0 to 47.2 GHz
76 to 81 GHz
134 to 141 GHz
241 to 250 GHz
The relevant sections of part 97 are 97.207 and 97.209
https://www.law.cornell.edu/cfr/text/47/97.207
https://www.law.cornell.edu/cfr/text/47/97.209
On 06/17/2018 02:05 PM, Bruce Perens via Ground-Station wrote:
> All licensed Amateur frequencies can be used for uplink, right?
> On Sun, Jun 17, 2018 at 10:29 AM, Douglas Quagliana
> <dquagliana at gmail.com <mailto:dquagliana at gmail.com>> wrote:
> Trying to squeeze this into my workload...
> Page 10. C 18. The frequencies at 1.2 GHz (uplink-only) are
> missing from their list of frequencies that are used by small
> satellite operators (assuming they include the amateur satellites
> under their definition of small satellite operators.
> Regards,
> Douglas
> On Jun 15, 2018, at 12:20 PM, Bruce Perens via Ground-Station
>> The Federal Register Information:
>> https://www.federalregister.gov/documents/2018/05/24/2018-10943/streamlining-licensing-procedures-for-small-satellites
>> <https://www.federalregister.gov/documents/2018/05/24/2018-10943/streamlining-licensing-procedures-for-small-satellites>
>> The FCC's document:
>> https://transition.fcc.gov/Daily_Releases/Daily_Business/2018/db0417/FCC-18-44A1.pdf
>> <https://transition.fcc.gov/Daily_Releases/Daily_Business/2018/db0417/FCC-18-44A1.pdf>
>> On Fri, Jun 15, 2018 at 10:11 AM, Bruce Perens <bruce at perens.com
>> <mailto:bruce at perens.com>> wrote:
>> It says in the Federal Register that we have until July 9 to
>> submit our comment in the small-satellite NPRM. I'm starting
>> to write now. Please send your ideas my way.
>> Thanks
>> Bruce
>> Bruce Perens K6BP - CEO, Legal Engineering
>> Standards committee chair, license review committee member,
>> co-founder, Open Source Initiative
>> President, Open Research Institute; Board Member, Fashion
>> Freedom Initiative.
>> President, Open Research Institute; Board Member, Fashion Freedom
>> Initiative.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180617/aa834b8d/attachment.html>
