[Ground-station] pop quiz!
Zach Leffke
zleffke at vt.edu
Mon Jun 11 04:50:55 PDT 2018
Do you want answers (or attempts at answers) on the list or direct to you?
-Zach, KJ4QLP
Aerospace Systems Lab
On 6/8/2018 10:36 PM, Michelle Thompson via Ground-Station wrote:
> Phil Karn KA9Q has been working on something fun for us. If you enjoy
> this quiz, please feel free to share it and let him know!
> Given the documents that you can find at:
> https://github.com/phase4space/AO-10-blueprints
> Quiz for fans of the AMSAT Phase IIIB/AO-10 blueprints
> Phil Karn, KA9Q
> Question 1: AO-10 carried a 400-newton kick (rocket) motor that used
> hypergolic propellants. It was fired only once, but the burn duration
> was 1.68 times longer than planned. Why? (Note: the burn did *not* end
> because of propellant depletion.)
> The cause can be discerned from the prints; i.e., it was a hardware
> problem, not a software bug or operational mistake.
> Optional hint 1: The burn was timed in hardware.
> Question 2: The ground test of the hardware consisted of successfully
> executing a maximal length burn. What tests could have revealed it?
> Question 3: Although the first burn did not deplete the propellants,
> it was not possible to fire the engine again because of insufficient
> helium pressure. Why? (Hint: the cause was not insufficient helium
> loading before launch.)
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180611/74000754/attachment.html>
