Sat Jun 2 10:32:33 PDT 2018
Do you have any links to proposals or research? I can add this paragraph
and some citations to our Research Gate project page and see if anyone in
that network might have similar work going on.
On Sat, Jun 2, 2018 at 10:13 AM, Bruce Perens via Ground-Station <
> We've recently heard proposals and seen some research regarding the use of
> radiation shielding to make it possible to use consumer or industrial grade
> parts rather than rad-hard ones. A cubesat called ShieldSat 1 flew to test
> some of this. My mostly-innumerate grasp of atomic science tells me that
> this can only go so far, and that when high-energy particles hit shielding,
> you get a particle shower that is sometimes more harmful than the original
> particle. But I don't have numbers.
> The proposal is to use the outer layer of structural aluminum, and an
> inner laminate of tantalum, titanium, and other dense materials with
> different atomic numbers from each other. Using titanium directly as the
> structural material, rather than aluminum, is possible; but it takes a more
> sophisticated (and expensive) laser cutter, and it has to be heated to be
> bent without cracking.
> What I'd like to hear would be numbers for reasonable thicknesses of these
> materials, and the degree to which they can, for example, make a
> van-Allen-crossing orbit look like LEO.
> Thanks
> Bruce
> Standards committee chair, license review committee member, co-founder,
> Open Source Initiative
> President, Open Research Institute; Board Member, Fashion Freedom
> Initiative.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180602/c03ba0c4/attachment.html>
