[Ground-station] Phase 4 Ground Engineering Report
Sat Jul 28 14:05:19 PDT 2018
Welcome to the engineering report for Phase 4 Ground!
This issue: Snaps, IP Multicast, Multicore, PlusUltra, The
Trans-Ionospheric, Linux in the Ham Shack, Block Party, and Space Policy.
27 July 2018
Ubuntu Snaps for SDR
Snaps are containerized software packages for Ubuntu. They are designed to
be simple to create, install, run, and update on all major Linux systems
without modification.
Steve Conklin, our platform lead, believes that Ubuntu Snaps are a great
solution for some of our SDR work. He will be looking to work with Phil
Karn's SDR package. What needs to happen next is getting the Karn SDR
package updated with any recent work, and getting it to reliably build. If
you can help with this, then contact Steve Conklin (steve at conklinhouse.com)
and proceed.
The current SDR code is here: https://github.com/phase4ground/ka9q-sdr
IP Multicast Engineering Adventures
Phil Karn found what he thought were two annoying Linux kernel bugs last
week.
The first was indeed an ipv4 multicast routing bug. The second was in the
ALSA sound driver, and turned out to be a hardware-specific driver setting
problem.
First, the ipv4 bug. An arbitrary hard-coded limit of 10 pending entries in
the multicast routing table caused multicast traffic to never start on a
network with lots of multicast traffic (e.g., at University of California
at San Diego UCSD) when the stream you want had low activity.
Phil could usually (but not always) get audio to flow when the receiver was
tuned to NOAA Weather Radio (continuous), but often not when tuned to APRS
(intermittent). And he could never get decoded AX.25 frames (every 5-10 sec
or so).
These things worked well in other networks, but not at UCSD.
Phil filed a bug report with the Linux kernel developers who confirmed it
was a problem and proposed a patch. Phil reported that it only took a few
hours to get a response.
Open source for the win!
Of course, as Phil notes, open source only works when enough people use a
functionality or protocol to create enough test cases that cover enough of
the potential search space to where you will get the weird results that
turn out to be subtle bugs.
When Phil dug into the sound driver bug, it turned out to be a glitch in
the Intel HDA timing system in his particular Dell laptop. There's a lot of
this glitchery in this particular chip, and there are pages and pages of
notes on various driver options to set to work around it. He found a
discussion of what sounded like his problem, tried the suggested options on
the kernel module, and the problem cleared up.
The problem was that with the default settings, an interrupt didn't get
registered in the Linux kernel. He doesn't understand why it worked at all,
but it's working now, and seems limited to particular laptop hardware. The
symptom was that callbacks from the portaudio library stop coming, and the
thread that calls them is stuck in a poll() that never returned.
Multicore Programming Notes
Threading is powerful but also full of pitfalls. Phil relies heavily on
pthreads. With even embedded processors often having two to four cores,
anything worth coding really needs to take multiple cores into account and
use them as effectively as possible. However, not only do you have to be
concerned about race conditions, but also memory fencing, store fending,
and load fencing.
Race conditions are somewhat self-explanatory. One set of instructions
starts before input data is available or calculated in time. That means
stale or missing data is used instead of expected timely results. Race
conditions can be managed in several ways, including the use of flags or
semaphores or guaranteed delays.
Memory fencing is when you ensure that memory operations occur in the
correct order. If you have a single linear set of operations, this is
inherent in the code. If you have concurrent lines of code, then enforcing
proper shared memory access (both loads and stores) becomes critical.
PlusUltra!
Ultra96 work is proceeding. This effort is focused on getting Charles
Brain's LDPC decode into an FPGA (among other functions). The Ultra96 is
the leading contender for a development platform.
We've build bootable SD cards for the Ultra96 in a variety of ways. Methods
include the PetaLinux toolchain as well as utilities from Brennan Ashton (
https://gitlab.com/btashton/ultra96-notes/tree/master).
Jan Schiefer has updated his instructions on building an SD card that
includes GNU Radio for the Ultra96:
https://github.com/phase4ground/PlusUltra
This rewires the console port to come out of the console connector, adds
drivers for some popular Realtek-based USB Ethernet dongles (so you can use
Ethernet, or even TFTP-boot!), and adds gnuradio (version 3.7.13.4),
including UHD.
Trans-Ionospheric Badge
100 production badges arrived today (Friday 27 July) and another 100 will
arrive next week. These hackable conference badges are amateur radio themed
and are planned to interact with Phase 4 Ground radios as a wearable
extension of the user interface.
Proceeds directly benefit Phase 4 Ground radio development board efforts.
Our major sales event for Trans-Ionospheric badges will be at DEFCON, which
is coming right up.
The good news here is that we have a cooperative vendor in the DEFCON
vendor room that has agreed to sell the boards at his booth. We are greatly
appreciative of this opportunity. It's a huge help to funding Phase 4
Ground and spreading the fun of #badgelife.
Phase 4 Ground, Open Research Institute, and Ettus Research will be part of
WiFi Village this year. Come visit us and have fun with SDRs and GNU Radio!
Tune in to the Linux in the Ham Shack podcast episode 238 to hear Michelle
W5NYV and Steve Conklin interviewed about Phase 4 Ground, Ubuntu Hams, Open
Research Institute, and a few other things. Thank you to everyone at Linux
in the Ham Shack for the opportunity to spread the news about open source
efforts in amateur radio! http://lhspodcast.info/
Block Party at GNU Radio Conference
The hardest part of Phase 4 Ground radios is on the receiver side. Having
complete DVB-S2 and DVB-S2X receiver blocks in GNU Radio, preferably
leveraging RFNoC, is a major (and ambitious) goal. We are making progress,
but we have a lot to do. We have organized a summit at GNU Radio Conference
in September 2018. It's called a Block Party, because we want to make some
blocks, and because we want it to be fun.
We will have a dedicated room for the week and volunteers ready to help
advise. We are bringing as much lab equipment as we can, a white board, and
plenty of enthusiasm. The goal is to produce blocks (or substantial
progress on blocks) for GNU Radio. We'll have some swag and quite possibly
some Trans-Ionospheric badges and other items available.
Space Policy Participation
Open Research Institute will be at Goddard Space Center to participate in
the Interplanetary CubeSat Workshop in August. We'll also be at the Open
Source CubeSat Workshop in Madrid, Spain in September.
The goal of participating and presenting at events such as these is to
advance open source hardware and software in the amateur radio satellite
service. There is a lot of work to be done here and we have a lot to learn.
Our views are distinct from, add to, and interact with, those of AMSAT,
ARRL, and others. We advocate a strong, committed open source approach and
are actively developing and refining our policy views in order to make open
source work easy and accessible and effective for anyone wanting to
contribute to the amateur radio satellite service.
Join our mailing list and find out more about Phase 4 Ground and other Open
Research Institute projects at https://openresearch.institute/
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180728/422a2d85/attachment.html>
