[Ground-station] 5GHz amplifiers
Bruce Perens
bruce at perens.com
Wed Apr 25 08:14:42 PDT 2018
Heat pads can be hand-soldered and then hand-desoldered using the 136F
low-temperature solder from Fast Chip on Amazon or ChipQuik.
On Tue, Apr 24, 2018, 14:49 KENT BRITAIN via Ground-Station
> An inventory of stencils does make the job easier.
> That ground/heatsink pad is very difficult to do without one.
> *From:* Bdale Garbee <bdale at gag.com>
> *To:* KENT BRITAIN <wa5vjb at flash.net>; Michelle Thompson <
> mountain.michelle at gmail.com>; Michelle Thompson via Ground-Station
> *Sent:* Tuesday, April 24, 2018 11:08 AM
> *Subject:* Re: [Ground-station] 5GHz amplifiers
> <ground-station at lists.openresearch.institute> writes:
> > The PC Board is the easy part.
> > Who installs that microscopic little thing?
> > Virtually has to be done by machine.
> Nah, that's a pretty big part. I place parts like that on prototype
> boards by hand with tweezers under my inspection microscope fairly
> routinely (lots of MEMS sensors are in this size range these days).
> It's important to have a decent stencil and fresh, fine particle solder
> paste. And a steady hand, of course...
> 73 - Bdale, KB0G
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180425/7e9924b8/attachment.html>
