Mon Apr 23 10:56:04 PDT 2018
A 5 to 26 GHz Vivaldi only weights 4.7 grams.
A 2-26 GHz Planar disk comes it at 1.9 grams
Minus coax of course. Kent
To: Michelle Thompson <mountain.michelle at gmail.com>; KENT BRITAIN <wa5vjb at flash.net>
Cc: Zach Leffke <zleffke at vt.edu>; "ground-station at lists.openresearch.institute" <ground-station at lists.openresearch.institute>
Sent: Monday, April 23, 2018 12:46 PM
Subject: Re: [Ground-station] Balloon Launch - experiments?
On 4/23/18 10:17, Michelle Thompson wrote:
> Five and Dime is where we're at.
> 5GHz up and 10GHz down. We have aspirations to move up, but our bread
> and butter is 5 and 10.
Then a surplus Omnitracs taco-shell antenna should do the trick for 10
GHz transmit (they're designed for Ku-band). We could avoid the need for
a directional receive antenna at 5 GHz by simply turning up the wick on
the ground (and using a directional antenna).
The antenna itself is metallized molded plastic. We'd have to extract
the motor and drive from a fairly heavy cast metal chassis. I haven't
looked at one of these things in a long time but I'm sure Kerry Banke
has a good stock of them.
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180423/8ae70185/attachment.html>
