[Ground-station] Call for discussion: ORI satellite program
Mon Apr 23 10:14:36 PDT 2018
When I was actively promoting AMSAT at academic conferences over the past
couple of years (IEEE, etc) I found out several things.
First. There are plenty of examples of great CubeSat work. There's enough
CubeSat engineering (open source) that has been figured out and tested in
orbit to where the starting point is significantly past where AMSAT
engineering seemed to be assuming it is. Phil is exactly right in that you
can buy or build from published work everything, at this point, to make a
pretty advanced CubeSat. You integrate whatever special job you want it to
do, and then get in line with everyone else for the paperwork trail. Basic
CubeSats are either a solved problem, or rapidly approaching one. They are
viewed almost like a commodity now, and the biggest area of work for many
of these academics is formation flying. Even constellations are old hat.
The number of predicted commercial launches over the next two years is
significant. The number of educational and science missions is projected to
be flat. That means that as a fraction of launches, educational and
scientific missions will experience additional pressure. Unless the number
of launches rapidly increases, that is. That may be why you are seeing
things like the DARPA rapid response launch challenge.
I'm on record about what I think should happen on the space side with the
QEX article I wrote with Howie DeFelice in late 2017, and I haven't changed
my mind since then. Don't wait for a launch to build. Network your butt off
and find out where you might fit. Be opportunistic.
Another surprising thing I found is that no one in the US academic scene
had any idea of who AMSAT was. This was not the case at all for the
European and Asian and South American professors/industry people that
presented work where amateur radio was incorporated and highlighted. They
knew who their AMSAT-XX people were, often by name. This was a big source
of concern to me because it meant AMSAT-NA appeared to be isolated and cut
off from some of the exact people that the amateur service is supposed to
be serving. Zach wrote a very good email recently about his views of his
potential role to operate for educational reasons and his ambitions to
carry this function out.
Asking around industry and labs in the US, I didn't get a different result.
Most people I talked to were surprised that amateur radio was still around
as an experimental force - like, surprised it still existed at all - and
were really surprised that we had a satellite service.
One of the functions of an organization is to market ideas and raise
awareness and enable collaboration across structured groups. I believe that
there's a lot of work to be done to show the value and achievements of
amateur radio in space to US based academic, scientific, and educational
institutions. It's something we can help with a little bit as ORI, but
can't solve. This is a problem really better addressed by an organization
like AMSAT. We're not a replacement for AMSAT. We were created to be a
member society specializing in open source digital work. This work was
judged to not be a priority at this time. The work should go on with
whoever does value it, and we should remain open to potential future
support from AMSAT.
My goal is to get a world-class DVB-S2/X implemented and working for both
terrestrial and space. I'm all in on this and will do my best.
On Mon, Apr 23, 2018 at 12:12 AM, Phil Karn via Ground-Station <
> On 4/22/18 19:00, Bruce Perens via Ground-Station wrote:
> > I don't know anything about satellites. I am trying to rectify that
> > issue as fast as possible,
> Don't underestimate the value of experience. As hidebound as AMSAT may
> have become, they do have a track record that began long before the
> cubesat era. In fact, the cubesat idea was invented by Bob Twiggs
> operating more or less under the broader amateur satellite umbrella.
> Satellite engineering is inherently multi-disciplinary; that is in fact
> a lot of its value to engineering education. Lots of skilled people are
> needed beyond the obvious electrical and computer engineers. A gap in
> expertise can cause an entire project to fail because of overlooked
> problems. Classic example: thermal design. A satellite in space is its
> own little planet with its own radiation balance, just like the earth.
> The physics is well understood, it just takes an engineer who
> specializes in that stuff (usually mechanical or aerospace) to apply
> their skills. I understand the basics, but EEs at Cornell were not
> required to take thermodynamics so I didn't.
> > One thing that has struck me about AMSAT is that they have so far
> > operated with only NASA as their launch partner,
> That's not actually true. Several major satellites with major AMSAT
> North America involvement flew on the European Ariane, such as Phase
> III-A, Oscar-10, Oscar-13, the Microsat constellation (Oscars 16-19),
> Oscar-40 and probably some others I've forgotten. Numerous cubesats with
> various degrees of AMSAT involvement have flown from Ukraine and
> probably Russia, India and Japan. Only China (and North Korea) are
> excluded for political reasons.
> I did the telemetry system for ARISSat-1, deployed from the ISS in 2011.
> It was designed and built in the US but launched to the ISS on a Russian
> Progress, deployed by Russian cosmonauts during an EVA and operated
> under a Russian name (Kedr), license and callsign. (And the Russians
> gave us virtually no credit, which really pissed me off.)
> But cooperation between US AMSAT and the rest of the world has
> definitely diminished in recent years because of ITAR phobia.
> > and they've always
> > built a satellite only after there was a clear launch opportunity.
> This *is* a problem. Traditionally they get a launch opportunity with
> *just* enough time to build something *if* the launch schedule slips (as
> it almost always does). Then there's a mad rush to get the hardware to
> the launch pad. Software is invariably an afterthought, often literally
> sent up after the hardware.
> So AMSAT rarely does anything truly new, because they never allow
> themselves the opportunity to develop stuff so it can be ready when the
> launch opportunity appears. Like interesting digital stuff. (I've
> already let it be known that I'm simply uninterested in doing another
> telemetry system for a primarily analog satellite.)
> > So, my idea was to run an "Opportunistic" satellite program, in which we
> > would construct cubesats and P-pods without a clear launch opportunity
> > in advance, and then approach commercial launch providers (and others)
> > with ready-to-fly equipment in hand when opportunities come up.
> I'd go farther than that -- an applied research program to develop and
> prove (on the ground) novel (to hams) concepts so they can be ready for
> actual development when the opportunity appears. The initial hardware
> need not even be intended to resemble anything we could fly; it would
> just be a proof of concept.
> > We can also make better academic partnerships. Fully 50% of academic
> > cubesats fail, due to lack of experience, poor component choice and
> > engineering decisions, and because they don't understand radio well.
> Or thermal engineering...or mechanical structures, or lack of knowledge
> of aerospace design standards...
> > There is also the issue that University projects aren't well equipped to
> > continue to control the satellite over a period of years, and that FCC
> > doesn't want paid employees as satellite licensees or operators if
> > they're licensed in the Amateur service.
> Correct. This has been controversial in some quarters but I can't think
> of a more worthwhile use of the ham bands than to support science and
> engineering education. I don't care if they're university students or
> individuals puttering in their basements.
> Where we have to be careful is when the main purpose of the satellite is
> as a "bus" to support some large science project or commercial
> engineering project, and the satellite operator is just after us for our
> spectrum. There has to be a significant ham (and educational) component.
> > So, my thought was to partner with universities and to provide them with
> > finished cubesats with room for their experiment, using Karn's modem
> > rather than the poor AX.25 implementations they usually use, and
> > operating the satellite for them after launch. They would get the launch
> > and run their experiment. The satellite would be a hamsat during or
> > after the experiment.
> There's already a flourishing cottage industry supporting cubesats. If
> you've got the money, you can buy everything you need to support some
> experiment.
> For example, I think ISIS (bad name choice) will sell you a complete
> attitude control system for about $200K (the last time I checked). This
> is not only outside of our budget, it bothers my sensibilities as a ham.
> What drew me to AMSAT in the early 1980s were truly clever hacks like
> stabilizing satellites with bar magnets and painting measuring tape
> antennas white and black to spin them with solar photon pressure. W1HDX
> once designed a 137 MHz circularly polarized APT patch antenna out of a
> 4'x8' sheet of Home Depot polyurethane insulation with aluminum on both
> sides. You lay it on your roof, paint it to match and nobody in your
> neighborhood will even know you have a prohibited outdoor antenna. This
> is ham ingenuity.
> Unfortunately, these great hacks are getting a little long in the tooth.
> Momentum wheels and control electronics simply shouldn't cost that much,
> and we need to use our brains to figure out how to do it cheaper and
> better.
> Phil
URL: <http://lists.openresearch.institute/pipermail/ground-station-openresearch.institute/attachments/20180423/1f9c9c01/attachment.html>
