[Board] Fwd: RSA5000-VSA for PO# P307958
Fri Jul 16 11:32:42 PDT 2021
---------- Forwarded message ---------
From: RIGOL Support <license_activation at rigoltech.com>
Date: Fri, Jul 16, 2021 at 11:28 AM
Subject: RSA5000-VSA for PO# P307958
To: <ori at openresearch.institute>
Cc: Stephanie Ahrens <confirm at tequipment.net>
Thanks for your order. This is the delivery of your option: RSA5000-VSA
on order: P307958
It contains the product key for your instrument software option.
Make sure to print or save a copy for your records.
Use the KEY in the PDF and your instrument serial number to generate the
software license code on this website
<http://licenseen.rigol.com/CustomerService/ProductRight_EN>.
The generated code may be a string or a file depending on the model. Follow
the instructions on the PDF to enter the license into the instrument.
For more information you can watch this video <https://youtu.be/6XURK9G3DIE> on
the license activation steps or search for more information in our Support
Center <https://rigol.force.com/support/s/>.
Should you have a question or concern about this email, your license,
service, warranty support, technical, software, or application support feel
free to contact us directly at our offices in Beaverton, Oregon which are
open 7-5 Pacific Time, Monday-Friday.
Sincerely, The Team at Rigol USA
RIGOL Technologies
8140 SW Nimbus Ave.
Beaverton, OR 97008
toll free: 877-4-RIGOL-1
help at rigol.com
www.rigolna.com
URL: <http://lists.openresearch.institute/pipermail/board-openresearch.institute/attachments/20210716/1f8e52c7/attachment-0001.html>
Type: application/pdf
URL: <http://lists.openresearch.institute/pipermail/board-openresearch.institute/attachments/20210716/1f8e52c7/attachment-0001.pdf>
